stealth cover
Old Jul 31, 2008 | 07:27 PM
dodge_24's Avatar
stealth cover
has anybody used or heard of the vp44 stealth cover
was trying to find any info good or bad i don't want to tap the injection pump wire
because ive heard that the injection pump place will not take it as a core
would like to use it for the edge comp
thanks
Old Jul 31, 2008 | 08:20 PM
badme's Avatar
I have one, but for warranty purposes they have caught on and won't accept them. For a core I do not see why they would care if it was tapped or not. That is why it is called a core.
Old Jul 31, 2008 | 09:32 PM
JIT's Avatar
JIT
Why would you send in a core with the stealth cover on it? I have used it and it worked great. Am I missing something?
Old Jul 31, 2008 | 11:27 PM
dodge_24's Avatar
Not With The Stealth Cover With The Wire Tap On The Pump How Hard Is It To Install
And I'm Looking For A Cheap Edge Comp Box Anybody Has One For Sale
Old Aug 1, 2008 | 07:45 AM
badme's Avatar
Yea, you take the cover off and put the original cover back on before returning the core.
Old Aug 1, 2008 | 07:46 AM
badme's Avatar
Take old cover off, bolt on new cover, turn in screw, attach wire, you are done.
Old Aug 1, 2008 | 12:15 PM
Lil Dog's Avatar
Check the classifieds. Good stuff in there!
Old Aug 1, 2008 | 04:26 PM
Djasik's Avatar
I really recommend the stealth cover! I tapped the orginal pump wire, when the pump went out they gave me 200 dollars less then what the core was worth. I went to 3 injection shops and that all offered around 200-300 dollars less then what the core was worth. I said its just a wiring harness whats the deal??? They all told me that the module had to be replaced, the harness was built in to it. I Dont know how much truth there is to it, but I couldn't really argue with them, I needed my truck running again. I bought my cover from another injection shop for around 50 dollars if I remember right.
Old Aug 1, 2008 | 06:51 PM
badme's Avatar
Every place in the world is going to take the cover off and see if the epoxy was pierced. It is no longer a secret. If you are getting the stealth cover just for core or warranty purposes save your money.
Old Aug 1, 2008 | 10:34 PM
need12v's Avatar
I like the stealth cover on my truck because it makes a better connection (short of actually soldering the wires together). As far as looking to see if the epoxy is pierced, you can put a dab of black RTV over top of the hole and hide 99% of the trace.
Old Aug 2, 2008 | 02:42 PM
Djasik's Avatar
I figure I stand a better chance with the stealth cover then a clearly spliced wire. Most shops around here think a superchip is performance. They're more into building pumps for overtheroad trucks, industrial engines. If the pump doesn't look tampered with, they could care less.
sodbuster03
May 23, 2007 08:11 PM
REDNECK-WELDING
Apr 24, 2007 11:29 AM
jlarmour
Apr 8, 2007 07:52 PM
B.A.Ram
Mar 1, 2006 10:35 PM
Cat Cracker
16
Nov 5, 2002 03:51 PM
