Starting With Ether???
Old Mar 10, 2006 | 12:23 PM
STACKED's Avatar
Question Starting With Ether???
Is starting your truck with ether bad? i have starting problems with my truck, fairly sure VP44 is going or gone but the only way the truck will start is with ether. it runs ok when started, sometimes under WOT shifting in 3rd or 4th the truck will cut out hard at high RPMs (head almost hits dash) for a split second and come back and run fine.
codes are p0463, 0237, 0253, 1688, 1693
What do you think of all this
Old Mar 10, 2006 | 12:29 PM
RustyJC's Avatar
If your grid heaters come on when you have a good dose of ether in the intake, it's going to ruin your whole day!
Rusty
Old Mar 10, 2006 | 12:37 PM
24valvepuller's Avatar
just un-hook the grid heaters first
Old Mar 10, 2006 | 12:39 PM
JD730's Avatar
0463 is fuel level sender voltage too high
0237 is the Map sensor voltage too low
0253 is Injection pump fuel valve open circuit
1688 is an "Internal injection pump controller failure"
1693 mean some codes where cleared from the JTEC module
Rusty is right of course ether and red hot air intake heater are not good things to be mixing. And I've seen different diesel engines that have been ethered and they had their top rings broken and it scored the bore alittle bit.
I think its time for a new VP
Old Mar 10, 2006 | 12:48 PM
STACKED's Avatar
then will te wait to start lite stay on? and should in just tape the wires up?What do i do about the voltage on the MAP?
Old Mar 10, 2006 | 12:55 PM
HOHN's Avatar
Fix what's wrong instead of ruining your truck with ether.
This is a case of penny-wise, pound-foolish if you keep using the ether.
Old Mar 10, 2006 | 01:43 PM
gunracer1's Avatar
it would be pretty hard to spray to much either in your truck, just a small shot to get it started won't hurt it. but try this for me. next time you go to start your truck, disconnect the lift pump and try to start it. if it starts, plug the lift pump back in. and if you are short on cash just put a switch in the power line of the lift pump. i know guys that are running 2 years with it wired in like i suggested.
Old Mar 10, 2006 | 03:47 PM
STACKED's Avatar
i will try this but if i have a extra pusher pump already does this work the same?
Old Mar 10, 2006 | 05:58 PM
wheelo90's Avatar
My Buddy was telling me the other day how some diesels can get "addicted" to the ether. To the point that they will only start with ether. How this works I dont know, But it sounds to me that you have some pump problems.
Wheelo
Old Mar 10, 2006 | 06:00 PM
Geico266's Avatar
Can't agree more.
Fix what's wrong.
Old Mar 10, 2006 | 06:11 PM
IA_James's Avatar
Wheelo
I've seen this happen with alcohol race motors, not sure why. Just seems like they get to where they won't start without it.
jacob_armour
Feb 18, 2009 01:44 PM
iker42
Nov 14, 2007 01:07 PM
cwoodall
14
Aug 27, 2007 05:16 PM
none0000
17
Apr 30, 2005 06:37 PM
dieslcruisrhead
Jan 21, 2005 12:09 AM
