stage 2 or 3 snow ?
stage 2 or 3 snow ?
whats the differnece between a stage 3 and a stage 2 snow kit that really warrants a $200.00+ increase in price whats the advantages of going with a stage 3
stg 3 is a continous spray system that has its own little ECM that doesn't just read boost pressure, but EGT as well.
It's supposed be more of a set-it-and-forget-it setup for the towing guy who doesn't want to worry.
I personally think the Stg 2 with the 220psi upgrade is all a person should ever need.
Stg 3 is very heavy towing guys, imo.
The stage 3 will save a TON of water/meth as it is only sprayed when actually needed. This isn't a great big deal if you have a large tank mounted somewhere but if you are going to use the small tank included with the system you can run low fast. Also I don't like to spray the water unless really necessary so the stage 3 helps in this regards as well.
Doug Smith
Doug Smith
Stage II is all I ever felt the need for...but I don't tow long distances and I actually like scanning the gauges and throwing switches when needed!
Really depends on how you use it, I guess.
Reports from those that have the stage III all seem to love it.
RJ
RJ
Red3quarter
Dec 12, 2009 11:12 PM
OT-OF-Here
14
Oct 18, 2005 12:28 AM
