stacking boxes
Old Nov 7, 2005 | 04:58 PM
chevyryan6's Avatar
stacking boxes
I've got a TST 3 box, and was curious about stacking the Edge EZ or comp to it. I know that you shouldn't stack the TST with the Superchips programer due to the timing problems. Any advice would be taken into consideration, and I know I need injectors, pusher pump, etc.
Old Nov 7, 2005 | 05:13 PM
dodgediesel4x4's Avatar
Many folk stack it w/ a Ez, but you can't stack it w/ the comp. You can leave the comp in ez mode (wire untapped) and have the adjustability of both worlds.
Old Nov 7, 2005 | 06:26 PM
harleydnut's Avatar
Pardon my ignorance but what exactly does the TST do?
Old Nov 7, 2005 | 07:17 PM
chevyryan6's Avatar
the TST does basically the same thing as the Edge Comp, more power, go to http://www.tstproducts.com for more info
Old Nov 8, 2005 | 01:41 AM
95ram's Avatar
Stacking a timing box with the TST is a good move. You could stack it with an EZ, Diablo power puck, or a van aaken. My chose would be the Van Aaken though thats not what I currently have stack with my TST. I have my timing box hooked to the MAP and the the TST to the timing box. You'll notice bottom end improvement. You can cruise with the TST off and get a couple MPG improvement. I did anywho.
Old Nov 8, 2005 | 08:45 AM
RowJ's Avatar
Sort of but not exactly.
The Edge Comp has timing added to the increased fueling.
The TST PM3 is a fueling box only....increases the amount of fuel based on boost level being generated....starts adding fuel at 3 psi boost.
Stacking an EZ or a Van Akken on a TST box is an excellent way to go....best of both worlds. Timing and early fueling from the EZ (on high with stock injectors)...Mid range & top end fueling from the TST. I love mine. More expensive than the Edge Comp, if you don't already have either box, but also more reliable, IMHO.
Stacking boxes has been around for a few years, with absolutely no negative side effects!
RJ
t-boe
Jan 4, 2007 08:35 AM
rubbert
13
Apr 22, 2004 02:19 PM
Gene007
Oct 27, 2003 03:43 PM
John_P
24
Jul 13, 2003 08:59 AM
