speedometer correction
Old Mar 5, 2003 | 05:05 PM
ridofpwrstroke's Avatar
I looked on the search and couldnt find anything so I thought I would ask the question-When you change tire size your speedo will be slow, how do you correct it? Is it like my old truck with a gear in the transfer case so that you could just get the right gear, or is it like my old f350 that you could recalibrate it in the computer, or how do you change it? I just put on 315/75/16 BFG's which are 35's pretty much and she's running a little slow. Probably 5 mph. Any help would help me out.
Old Mar 5, 2003 | 09:46 PM
777 MECHANIC's Avatar
Re:speedometer correction
I was off 13% from 245's to 315's. Look at the Abbott ERA at<br>http://www.atrol.com/. Workd very well. You program in the tire size you went to and it makes the correction.
Old Mar 5, 2003 | 10:54 PM
4x4's Avatar
4x4
Superlift Tru-Speed. http://superlift.com/speedcal.asp
Thats what I used. EASY ;D
Old Mar 5, 2003 | 11:46 PM
StakeMan's Avatar
[quote author=4x4 link=board=7;threadid=11835;start=0#112245 date=1046926482]<br>Superlift Tru-Speed. http://superlift.com/speedcal.asp<br>Thats what I used. EASY ;D<br>[/quote]<br><br>What he said.
Old Mar 6, 2003 | 10:44 AM
I will go with the superlift because you can reprogram for two different size tires. Up here one for the winter and one for the summer is a nice feature considering we swap tires all the time. Thanks for the replys.
Old Mar 6, 2003 | 12:12 PM
StakeMan's Avatar
I have mine under the hood. Where it shouldn't be. But it has not given me a single problem.
Old Mar 6, 2003 | 04:26 PM
RickCJ's Avatar
I had my ecm programed for bigger tires. Any competent Dodge dealer with the ORB should be able to change the pinion factor and tone ring readings to set your speedo right on. Hard part is finding a competent dealer. Only a 5 minute job.
Old Mar 6, 2003 | 05:56 PM
StakeMan's Avatar
The dealers tried many times but could not get the job done. Adding the box was a lot easier than dealing with the dealers.
Old Mar 7, 2003 | 07:08 PM
tmiller24's Avatar
I install one of these on my Goldwing cause I wasn't happy with the accuracy of it's speedo.<br><br>http://www.blackrobotics.com/<br><br> Tony
kfm61
Mar 14, 2007 09:15 PM
seralan
Mar 2, 2006 04:20 PM
98 2500
Feb 29, 2004 12:15 AM
commando
20
Apr 26, 2003 06:30 AM
ridofpwrstroke
Mar 8, 2003 12:18 AM
