Speedo ?
Old Mar 6, 2008 | 11:52 AM
ellerman's Avatar
Speedo ?
I'm about to change gears to 4:10 and go to 37" tires. What is the best route to go for making my speedometer correct? Currently I have 3:54's and 315's and am off by about 5mph. Will a Smarty correct gear ratio and tire size or just tire size? Thanks
Old Mar 6, 2008 | 12:16 PM
Philabuster's Avatar
Gear ratio does not matter because the pick up sensor is on the differential ring gear itself--which is directly counting rear tire revolutions.
Smarty will correct your speedo regardless of the gear ratio. You can change tire size in 1/4" increments.
TJE
Mar 9, 2011 06:48 PM
Paul S.
Feb 20, 2003 05:29 PM
Monty
Feb 9, 2003 05:07 PM
chdiesel
Oct 31, 2002 03:22 PM
