special concerns for 500hp
Old Dec 30, 2005 | 08:27 AM
getblown5.9's Avatar
My combo this year will end up being:
PS62 or 64 (undecided) wastegated at about 45psi
Mach 4's
Drag comp
stock HO vp44
that should be close to enough fuel and air for 500hp but the concern is this:
will I need headstuds at 45psi?
will i need to fire/0-ring the head?
headstuds can be done farily easily...roughly $400, but I know at this point i cant afford the cost and downtime required to o-ring the head. I just dont wanna run into problems with ~500hp at 40-45psi
Old Dec 30, 2005 | 09:32 AM
banshee's Avatar
Headstuds would probably be good insurance, but o-rings aren't needed at 45psi.
Old Dec 30, 2005 | 09:39 AM
thats what i was thinking.
$1400 turbo
$1000 injectors
$100 for drag upgrade
$400 for studs
time to start saving...as long as i hit 501hp ill be happy
Old Dec 30, 2005 | 10:09 AM
ratsun's Avatar
I killed a HG at 50 with twins so I would think 45 with a single would be the same or worse. IMHO do at least studs, its not that big of $$ compared to when you have to pull the truck down for 2-3 days to change the HG. Also while its down you will probably want to deck and o-ring ect so the costs climb rapidly! Just my $.02 from my experiences
Old Dec 30, 2005 | 04:25 PM
RowJ's Avatar
Just a reminder.... Make sure your fully warmed up before playing hard at 45 psi !!!
This is not heresay.... unfortunately it's first hand expirience.
RJ
Old Dec 31, 2005 | 01:15 AM
cumminsdriver635's Avatar
I hope you are planning on a clutch too.
Eric
mstordahl
14
Sep 20, 2005 08:37 PM
Stomp
Feb 2, 2005 05:31 AM
clc900
Sep 10, 2004 01:41 PM
CrewCabCummins
Aug 7, 2004 09:07 PM
04ctd
Feb 19, 2004 10:26 PM
