Speaco Intercooler Installed!
Old Oct 9, 2006 | 09:54 AM
Bobcat698's Avatar
Spearco Intercooler Installed!
Got my new SPEARCO Intercooler installed.
This thing ROCKS!
Turbo Spoolup is VERY much improved, I can't believe how much difference it made. I'd say cruising temperature is 100-150 degrees cooler.
It takes a LOT longer to hit 1600 on a WOT run from a dead stop.
This thing darn near spools as good as stock, I am very surprisesd. It flat out gets up and GOES! Black smoke is decreased from a dead stop and the charger just flat out SPOOLS. If I can get a boost gauge video I'll post it up.
All around throttle response and acceleration is more crisp, and the power gain is awesome. Truck is much more enjoyable to drive in town with the big charger.
Here is a video I shot: (Closed course professional driver)
Click here to see Video
Yes, my truck is dirty.. Too busy working on it getting ready for Houston to CLEAN it..
All in all WELL worth the money, great upgrade!!
Old Oct 9, 2006 | 10:09 AM
AlpineRAM's Avatar
Some questions- are the connectors of a smaller diameter than stock? It looks like that on the pics.
If yes did you adapt the whole pipes or use an adapter?
The new IC looks a bit thicker than the stocker, was there a problem installing the AC cooler and the tranny cooler with the new IC?
TIA
AlpineRAM
Old Oct 9, 2006 | 10:11 AM
G1625S's Avatar
Are you rolling into the pedal to light it off, or did you just mash it?
Very sweet i/c BTW....wish I even had one
Don M's Avatar
DTR Advertiser
I have got to get one of those!!!!!!
Don~
Old Oct 9, 2006 | 10:12 AM
Dr. Evil's Avatar
Dude, youre out of fuel
Old Oct 9, 2006 | 10:18 AM
Bobcat698's Avatar
Sigh
Drove about 150 miles with solid bump stops on, with 1 inch of travel.. Probably knocked something loose in the tank. Makes me happy.
Old Oct 9, 2006 | 10:19 AM
Bobcat698's Avatar
I have my AFC adjust so that I can MASH it off the line and it still lights very nicely.
It is VERY important that you properly adjust the star wheel with these big chargers.
You can have them spool a LOT better if you tighten them up a bit.
Old Oct 9, 2006 | 10:22 AM
Bobcat698's Avatar
Some questions- are the connectors of a smaller diameter than stock? It looks like that on the pics. Yes, the connectors are smaller, but don't offer the restriction of the stockers "square" inlet.
If yes did you adapt the whole pipes or use an adapter? The IC kit includes new IC to turbo & IC to intake manifold pipes. The connections at the intercooler are STRAIGHT connections with no reducing.
Just some slight tweaking with the lines got everything lined up nicely.
Old Oct 9, 2006 | 10:59 AM
LanceD's Avatar
what do those things cost?
don't forget to update your sig
Old Oct 9, 2006 | 11:39 AM
gmctd's Avatar
Cool !
FYI, make sure it's that clean after you get here and B4 you make any runs - as you know, that dirt\mud coating severely limits radiating efficiency in an air-over heat-exchanger, not to mention restricting air flow-thru.
Just a friendly heads-up from a prospective spectator.....................
Old Oct 9, 2006 | 12:29 PM
Bobcat698's Avatar
Originally Posted by gmctd
Cool !
The dirt-mud coating is on the original IC.. which is now in storage. The new IC is clean as ever.
Old Oct 9, 2006 | 12:34 PM
HeberRam's Avatar
nice
Thanks for the input about temp and boost. Can you post where you got it from? I need to see if they make one for a 3rd. gen truck? I know that BD, and Banks make one, however, looking for one that is tested to 100psi.
Old Oct 9, 2006 | 03:01 PM
Bobcat698's Avatar
Originally Posted by HeberRam
Thanks for the input about temp and boost. I need to see if they make one for a 3rd. gen truck? I know that BD, and Banks make one, however, looking for one that is tested to 100psi.
They do make them for the 3rd gen trucks.
Spearco intercoolers are tested to 200PSI.
Old Oct 9, 2006 | 05:11 PM
blackdiesel's Avatar
Registered
now, if your recording your speedo, whos watchin the road???
do ya have a link??
Old Oct 9, 2006 | 09:54 PM
Mike Holmen's Avatar
The Guru
I'm supprised that it take so long to hit 100mph. I just found a rock hole in my intercooler to day. I was doing the leak air compressor test and found that my intake manifold plate leaks. I had to double clamp my intercooler hoses. The cooler fin area looks like its not quite as wide as the stock intercooler.
