sorry....wrong forum....again EGT's
Old Jul 7, 2007 | 02:56 AM
DeTree's Avatar
ok....so you can see by by Sig what I am running.......3-5 seconds at wot on smarty #2 and edge # 3 produces 1350 degrees plus......please tell me what is my next mod......turbo....injectors.....both.....downgrade .....this site is addictive and expensive.
thanks in advance
__________________
Old Jul 7, 2007 | 07:24 AM
Mike D's Avatar
DeTree, I hope you don't get offended, but I'm having a hard time trying to figure out what you're asking.
Old Jul 7, 2007 | 08:09 AM
dieselrob's Avatar
Well dpeneds, what do you do with your truck? Do you tow at all, or just a daily driver? Id recomend stepping up the turb then you can do more fueling. Injectors now would just be more heat. If you tow look at the 62-12 or 62-13ss, if not towing get the 62-14. That should get you more wot time. You can stay at 1350+ for a couple seconds and i wont hurt it, but dont go longer than 30 seconds.
Old Jul 7, 2007 | 10:24 AM
DeTree's Avatar
she is a daily driver but I load a 1800lb slide in and tow a 18 foot princecraft boat on the weekends
Old Jul 7, 2007 | 10:26 AM
DeTree's Avatar
just asking what mod would help reduce the egts....they are not out of hand but would like to have a little more wot time....no offence taken
Old Jul 7, 2007 | 12:11 PM
Mike D's Avatar
Got ya.
If she tows well with reasonable egts why worry? WOT runs at 1350 aren't bad, but I'm speaking from a drag racing perspective here. I'm 1350 at the 1/8..
More air is always nice, a 62/ 12 or 14 has been a great choice for many. With the auto and towing, I would look at the 12 housing.
Injectors will had more heat to a certain degree, pun intended... If you have stock injectors and want a little more punch, look at the Bosch RV275 injectors.
Old Jul 7, 2007 | 02:46 PM
Ph4tty's Avatar
How much boost are you seeing?
Old Jul 8, 2007 | 12:19 PM
DeTree's Avatar
23 to 25 psi at wot......she jumps to 1350 degrees and will keep climbing if I stay in it......which I don't
Old Jul 8, 2007 | 02:35 PM
clutch1's Avatar
add a tad more air on your stocker and see what it does. if you still need more air a 62/12 will work.
Old Jul 8, 2007 | 04:16 PM
clarson80's Avatar
23 to 25 psi at wot sounds low for your mods, do you have a boost elbow installed? A lot of guys are running up to about 34-35 with their stock turbos. I'm not saying a bigger turbo isn't in your future, but your stocker should be doing better than that. Just my $.02
Old Jul 10, 2007 | 10:50 AM
DeTree's Avatar
so if I was to get My boost up in around 30.....it would help the egts?
Old Jul 10, 2007 | 11:42 AM
pmtg's Avatar
more fuel w/o additoinal air = heat
more air (not necessarily boost) for the same amount of fuel = cooler EGTs
dont add injectors as that adds fuel and will in-turn add more heat. bump the boost to 30psi and take a look at EGTs. if still in trouble, downgrade your fuel (turn off the Edge) or add more air (bigger turbo).
Old Jul 10, 2007 | 11:45 AM
kas83's Avatar
To a certain degree, yes. More air will cool it down.
Montana2x2
Aug 31, 2010 10:12 PM
jondeere0405
Jul 30, 2008 06:59 AM
corey88
Jun 17, 2008 05:16 PM
Totallyrad
Jan 7, 2008 05:31 PM
b84u
Feb 20, 2006 01:04 PM
