Some tire info please
Ok so heres the deal....im needing some new tires to go on my new wheels...the problem im having is figuring out what size,right now i got 235-85's in the rear but ive got a 265-70 in the front....i like the 265 in the rather than a skinny 235....but that route i cant rotate them like they should be,as it is my 235's have like 3/4 in. between them....but the other day i seen a truck with 265 70's all the way around with no spacers and it had the same clearance, but it was a firestone mud tread and i dont need that. so can i run that wide a tire with no problems on a dually?
Ever seen a 255 85 there are slightly skinnier then the 265 but a lot taller. there are only 2 manufactures I've come across that make them toyo MT's and Bfg MT's. Just another option for you to think about
Toyo also makes A/T's and M55's in a 255/85R16. Just ordered a set of M55's to replace the 285/75R16's I have now. Looking to see if the narrower footprint will make a difference in MPG's. And you're right about it being hard to find many choices out there in that size.
More tire questions
What will the tires do to the fuel mileage?
Will I notice much power loss due to the oversized tires – especially when towing my 18 ft flatbed?
Is there a suggested wheel off-set, as I plan on buying wheels a couple months down the road
Will these tires rub without a lift? I was thinking of installing the 1-1/2 load leveling kit in the front.. Ideas? Advice?
Any advice is appreciated..
I've been running 285/75R16's for years on stock alloy wheels and no lift kit and haven't noticed any change in mileage or power from stock tires. They certainly look better on the truck. There will be a slight change in the speedo reading, but only a few mph at highway speed. I have a programmer that allows me to adjust my speedo. I think you'll be happy with the bigger tires.
mikcon
Nov 20, 2011 11:11 PM
coreydr2003
Competition / Pulls / OffRoad
Oct 5, 2007 09:56 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
GEN_X
15
Jan 4, 2006 06:03 PM
