SO Vs. HO long block
Old May 28, 2009 | 02:07 PM
Mopar_Man's Avatar
Ok I have found 2 Long blocks within 100 miles of me. Both are NON 53 blocks with around 80k miles. One is a 01 HO motor & the other is a 99 SO motor. I know the 01-02 HO motors have 17:1 Compreshion & the SO have 16.3:1. So my question is witch motor would be better to build? Its not going to be a race motor or anything like that. Its just going to be my daily driver that I would like to do a few more performance mods to. Seems like the higher compreshion would be good for a little more power seeing how im not going to be running extreamly high boost. Your input please. TIA
Old May 28, 2009 | 02:15 PM
benito's Avatar
I believe the pistons in 01 HO motors received better oiling/cooling from underneath, but the vp44 on HO motors cannot support really large injectors as well as the SO pump.
Old May 28, 2009 | 03:05 PM
Mopar_Man's Avatar
Well its only the long block. None of the external parts are going to be used. I will be swaping oll of my parts once the rebuild is done. As of right now I am leaning tords the HO long block.
Old May 29, 2009 | 12:43 PM
Mopar_Man's Avatar
Im getting the SO long block. Going to pick it up today.
Old May 30, 2009 | 01:25 AM
JasonblkZ06's Avatar
Why did you decide to go the SO route over the HO? I thought the HO had better pistons? Also more compression would give you some better turbo spool.
Old May 30, 2009 | 01:34 AM
Mopar_Man's Avatar
Well for one the SO was in mutch better condition. And like others have said the lower compreshion is better for building & I dont think .7:1 compreshion would have made that much of a diffrence.
Flatbed24v
Jan 29, 2009 07:13 PM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
