smoke switch?
Old Jan 6, 2008 | 07:34 PM
97dodgeram2500's Avatar
smoke switch?
my buddy put a smoke switch on his ford and i was just wondering if you could put a smoke switch on a good ole 12 v?
Old Jan 7, 2008 | 09:00 AM
91rangerturbo's Avatar
no you cannot. The 12 valve is non-adjustable with a switch or a box.
because it uses mechanical injection.
Old Jan 7, 2008 | 09:34 AM
BIGRIG10's Avatar
whats a smoke switch??? can you put it on a 24v. i like smoke
Old Jan 7, 2008 | 09:43 AM
dzlfarmboy's Avatar
There's lots of stuff you can do to a 12v for $0 dollarsto up the hp and make em smoke some. You can put a Valet switch on your p pump, but thats for when you have a lot of fuel turned to er and it helps cut back some for daily drivin
Old Jan 7, 2008 | 10:11 AM
RonA's Avatar
you could put a "t" in the line going to the afc. Put an anti drain valve in the line from the turbo or manifold so that air can only go towards the afc. In the second line put in an identical valve so that air can only go towards the afc. hook the other end to a solenoid and an air tank with 60 psi of air. When you activate the solenoid it will move the afc arm all the way forward at zero boost. That ought to make some smoke.
Old Jan 7, 2008 | 10:24 AM
haloman's Avatar
You could also do a "mystery switch" which will lock the converter, so you can lug it and smoke that way.
Old Jan 7, 2008 | 10:42 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
Is that AFC control only on the 12V motors? I don't seem to remember seeing any reference to that control on my 24V motor.
thanks
db
Old Jan 7, 2008 | 10:43 AM
haloman's Avatar
thanks
db
Just on 12v motors
Old Jan 7, 2008 | 02:42 PM
95dodgectd's Avatar
they are referrering to the smoke switch as the mystery switch and yes you can put one a 12v a 24v 32v , a ford or even chevy. go to this website and you'll see torque converter lock up switch thats what your looking for. have fun rolling coal. http://
www.tstproducts.com/index.asp?PageAction=Custom&ID=4
that site has instructions for 94-02
Old Jan 7, 2008 | 02:45 PM
95dodgectd's Avatar
wrong the 12v is adjustable with a switch what do you think a valet switch is and does and you can make a smoke switch see above post, most just call it a mystery switch or torque converter lock up.
Old Jan 7, 2008 | 08:14 PM
1stGen545's Avatar
Just do this.
https://www.dieseltruckresource.com/...t=valet+switch
Old Jan 8, 2008 | 01:09 PM
so if im understanding this correctly i do this:
1. take out the trans relay and put in a wire into the 2 plug-ins.
2.connect ground wire to b11 orange and balck wire.
3.hook it to a toogle switch in the cab and wal la. its done?
if i am worng can someone get me on the right path and also what kind of wire to use?
Old Jan 8, 2008 | 02:50 PM
95dodgectd's Avatar
this is where the jumper wire goes
and you tap the b-11 and that goes into the cab and connected to a toggle switch and then a you have a ground going to a toggle switch also and thats it. and then when you flip your switch it send signal that the torque is being turned on or something and its locks the converter untill you unlock it.
also just remember that its unless you take it out of overdrive its gonna put your tranny into 4th gear when you lock that switch, if you take it out of overdrive its gonna be in 3rd then just to let you know.
Old Jan 8, 2008 | 08:16 PM
thanks 95dodgectd. so what your saying is when i flip the switch does it automaticlly put the tranny in 4th or will it shift through all the gears intil forth and then wont come out of forth intil i turn it off?
Old Jan 8, 2008 | 10:38 PM
95dodgectd's Avatar
yup you got it, lets say your driving at 25mph and you flip you switch to lock up you torque conveter, its gonna put into 4th gear and lock the converter, and untill you unlock it, its gonna be in 4th gear, and if you slow down to say 20mph and just mash the throttle, your truck might smoke some depending on what you have done to your truck, and when you take it out of overdrive aka 4th gear it then would lock in 3rd. if you have a built up tranny and aftermarket converter it will be a lot more fun otherwise im sure you will slip t he converter.
