Smoke
Sure. A set of mach 6 injectors with an Edge Drag Comp or a TST PM3 Comp will throw a ton of smoke out. Match that with a Catcher ECM and you'll be covering highways.
suzukiZrider, the 24v's don't have an AFC spring and the 370's are usually for the 12v's. Don't know if you can even run them on a 24v.
Nope, 370's are a P-pump 12v only smoke stick. But they are close to the best at covering roads in thick black smoke.
On a 24v, a box of some sort, big "extrude honed" injectors, and a turbo that's not upto the task, will accomplish the same thing!
Chris
Chris
bensdad_canada
May 9, 2005 10:56 PM
