Smoke!
Old Apr 10, 2007 | 10:15 PM
Big Dblue's Avatar
Smoke!
How much smoke will i see with the Edge EZ, and will it be any louder? everything i have is stock.
Thanks
Old Apr 10, 2007 | 10:18 PM
Big Dblue's Avatar
I believe the EZ now don't get me wrong but i think it is 65hp thats should be a good start HUH?
Old Apr 10, 2007 | 10:26 PM
tx_2500's Avatar
you might see a bit more smoke, but not a whole lot. to really be rolling it you need some sticks and a box that taps the IP. or if you stack it with a smarty you should be able to get a bit more.
shouldnt be any louder. youd have to modify the exhaust to do that.
and yes, their rated at 65
Old Apr 10, 2007 | 10:41 PM
graphitecumnz's Avatar
Thanks
smoke: some, not much but it will be present upon low boost throttle mashing experiments.... want smoke, injectors, smarty and a TSTCE.
noise: no noise difference except maybe a little bit more timing rattle...
Old Apr 10, 2007 | 11:18 PM
rvman's Avatar
Edge EZ
I have EZ on my 01, did not see any more smoke(thank God) than stock.I was pretty surprised by the power over stock .However don't expect a tire shredding Hot Rod with the EZ only,it's designed more for towing .
Old Apr 10, 2007 | 11:44 PM
Ph4tty's Avatar
An ez a good start, but you really want to set up some guages before you start bombing. A smarty could bring in more fuel before boost which can produce smoke.
And I disagree with Mr graphitecumnz cuz a tst can help reduce smoke when stacked on a smarty and sticks =P
Old Apr 10, 2007 | 11:49 PM
kennyblatz's Avatar
i dynoed at 215 rwhp and 550 ftlb with an ez. a good safe start forsure
Old Apr 11, 2007 | 05:52 PM
Destination's Avatar
if you want smoke, I would say git a EDGE COMP, tap the wire, and unplug the map sensor
Old Apr 11, 2007 | 06:08 PM
pigsramdsl's Avatar
my 01 with the edge ez, straight pipe, and vulcan big line kit gives good smoke under heavy load and a nice big cloud from a dead stop to wot.
Old Apr 11, 2007 | 06:12 PM
scottsjeeprolet's Avatar
After you hook up the EZ then just unplug the MAP from the block, leave it hooked to the EZ. You will get a little more off the line power and smoke below 10psi boost.
the EZ and Comp both have boost fooling. Make sure you install your boost elbow and get gauges!
Old Apr 11, 2007 | 06:24 PM
pigsramdsl's Avatar
will unhooking map not give you a code?
Old Apr 11, 2007 | 06:29 PM
I have never had any codes with the map sensor un-plugged
Old Apr 11, 2007 | 07:26 PM
the only code i have experienced is an over boost code but it didn't set a CEL.
Old Apr 11, 2007 | 09:06 PM
Awall's Avatar
i had my MAP unplugged for a while and didnt throw any codes but one the truck completely died, about got me in a wreck.. Got a couple codes, SMARTY'd it and plugged the MAP back in and aint had a problem since.. Also aint had much difference in smoke between MAP and MAPless
Old Apr 21, 2007 | 04:53 PM
Big Dblue's Avatar
Ya i unplugged the map stock. and it through a cel. Didnt smoke anymore than pluged.
