Smarty, or Turbo?
Old Aug 6, 2007 | 01:35 PM
the496rocket's Avatar
Smarty, or Turbo?
I am thinking about getting a smarty, but I am wondering if I should put the money towards a turbo instead, look at my sig and tell mt what you guys think, right now, with the drag comp all the way up and the pedal mashed, there is a good constant cloud of smoke behind me, and the smarty with comp will only add more fuel, and it already looks like I have enough fuel...
Old Aug 6, 2007 | 01:55 PM
RowJ's Avatar
Since you have a Drag Comp already and are doing one or the other (right?)... I'd do the Turbo.
46 psi on your HX-35 is a serious condition and costing you big HP... IMO.
Parts from three different builders in your auto tranny....Interesting
RJ
Old Aug 6, 2007 | 02:25 PM
Yeah, im going to drill out my wastegate elbow larger to lower the boost, or get an adjustable elbow, is there a way to change the wastegate to open at about 35psi instead of 20?
Yeah, I wanted to pick what I wanted for my trans, I got dustys valve body, best Ive ever heard of and a great person to work with, plus hes only a 30 min drive for me. I ordered the suncoast kit and a guy I used to work with installed it, and Everybody says goerends converter is the best, seems to be good so far.
Old Aug 6, 2007 | 04:03 PM
Ph4tty's Avatar
That turbo is going to be in a hurting condition the way you're abusing it so you might as well count on replacing it soon.
Old Aug 6, 2007 | 04:45 PM
NoSeeUm's Avatar
Turbo
The Smarty will unlikely add much go-go on top of the Comp.
Jim
Old Aug 6, 2007 | 05:23 PM
kelownadiesel's Avatar
turbo for sure.Ive got a comp and smarty on my 01,no sticks and ya i can hit near 50 when its cold out too.You've got enough fuel for now,after you get the turbo upgraded then get a smarty,the drivability is unsurpassed.
Old Aug 6, 2007 | 09:03 PM
jeffropump's Avatar
Don't stack a Smarty with an Edge Comp or Drag Comp you'll just loose horsepower and or torque. I've seen it on the dyno and I've seen it on the drag strip. Jeff
Old Aug 6, 2007 | 09:09 PM
bamadzl's Avatar
I'd go with the turbo as well.
Brad
Old Aug 6, 2007 | 09:12 PM
Floorman's Avatar
turbo you need more air to take complete advantage of your fuel that you already have
Old Aug 6, 2007 | 11:15 PM
Ok, based on the opinions, I am planning on a turbo, what would be a good upgrade for around $500 to maybe $600? Id like a turbo that will still spool fast, will an hx40 be any good? Those usually go fairly cheap, I havent done much research on turbos.
Old Aug 7, 2007 | 12:43 AM
Fishin2Deep4U's Avatar
If you want fat spool and have a tight TC, I would look to a hybrid HX35 first. While they give up some performance on top to the HX40, they spool much much faster and are more pleasureable to drive.
And, this makes a great top turbo if you decide to go to daily driven twins.
Dave
Old Aug 7, 2007 | 01:07 AM
the drivability is still enough to buy it most would agree
Old Aug 7, 2007 | 01:12 AM
I disagree completely on that one!
The best driveability of any product IMO is the Edge Comp. Now if it was reliable, they would dominate the market.
As the HP goes up, especially with an auto, tight TC and tall gears, driveability really suffers with the Smarty.
Dave
Old Aug 7, 2007 | 07:11 AM
RowJ's Avatar
Dave
My expirience is just the opposite! I've got all the conditions you mention....and 35" tires... and the Smarty is the best driveability addition I've done.
But I agree with Jeff above, it does not help hp on a Edge Comp.
RJ
Old Aug 7, 2007 | 08:44 AM
If I order the 35/40 hybrid kit from HTT, what type of internal work needs to be done to the turbo to make it fit? Also, how much more powerful is the hybrid than a regular hx-35? as far as top end, I am looking for a fairly good performance boost. Thanks guys.
Eric
