Smarty and drag comp
Old Feb 22, 2006 | 01:38 PM
Big Smoky's Avatar
So can a Smarty be used in conjunction with a drag comp? Or do you need a CaTCHER for the smarty to be useful? How much power will the Smarty and a CaTCHER give you? (A ballpark figure) I don't know a whole lot about either of these mod's but I know they're awesome. Just wondering how well it would work with my set up. Thanks
Eric
Old Feb 22, 2006 | 01:47 PM
Mike D's Avatar
Catcher ECM and Smarty are one in the same almost, Catcher was a reflashed ECM and the Smarty is a downloader with Catcher software.
Old Feb 22, 2006 | 02:25 PM
JDGnut's Avatar
Eric.. the smarty is a programer... and there are different programs to choose from... with and without timing... so if you want to run it with the Comp.. just choose a program that does not included timing.. (The comp will do the timing.)
The Catchers are a reprogramed controller... the normal Catcher includes timing.. if you want to run it with a comp, find a "Special" Cather.. it does not change the timing.. There will be some Catchers fro sale soon, as more of the Smarties get out...
From the looks of things there are going to be a bunch in the local area.. (Smarties.) at one of the meeting, someone can unload the program from their truck.. and put it in your's for a trial run...
Bryan
Old Feb 22, 2006 | 02:27 PM
micah's Avatar
a bit off topic... but this thread made me think... what happens if someone that owns a Catcher re-flashes using the Smarty... is the catcher lost?
do the guys that own catchers still have their stock ECM's?
Old Feb 22, 2006 | 06:06 PM
graphitecumnz's Avatar
You wouldn't really lose the Catcher per se, the Smarty is essentially a Catcher with adjustability via the different downloads.
I'm sure some do...
Old Feb 22, 2006 | 08:59 PM
halfbakediesel's Avatar
If the catcher is in your ecm that would be the program that the smarty pulls and returns
Old Feb 22, 2006 | 09:09 PM
The Smarty does not pull out a program from your ECM.
mx684
13
Jul 24, 2007 07:52 PM
White00
Nov 19, 2004 09:18 PM
ratsun
Sep 26, 2004 11:16 AM
MoreSmoke
Jan 7, 2004 09:40 PM
hellotbone
18
May 16, 2003 04:40 PM
