Silencer Ring
The extra noise comes at an extra cost. There is NO extra power gain. That increased noise is caused by increased turbulence at the turbo intake. And that increased turbulence equaos reduced power.
The amount of power the turbine generates vs. the amount of power to create the extra noise would be a drop in the bucket.
That's like saying a top fuel motor makes less power with zoomies than with a full exhaust because it takes more power to make the noise with open headers.
The reason a top fuel engine makes more power is because it burns ten gallons of fuel in a quarter mile. They're paying for the increased noise with fuel usage.
silencer ring removal only helps if you also cut a hole in the bed and run stacks, preferably a Y pipe in the bed and two stacks...really tall ones.
then yes silencer ring removal will help in these cases
Perhaps you should take some of your own advice.
