Which shocks should I get?
Old Mar 14, 2005 | 08:13 PM
caleb c.'s Avatar
I really like the monroe gas magnums.They are the yellow ones.
Old Mar 14, 2005 | 11:27 PM
Cowhand's Avatar
Originally posted by phox_mulder
Does the 5100 come long enough for us with 5" lifts?
Part #s?
I took Shovelheads advice and also dropped Sam a line regarding them.
Got an email saying he needed to talk to me in person (phone) regarding them, so I'm thinking maybe they don't come that long.
phox
Pretty sure they do..... http://www.bilstein.com/html/applica...5100/index.htm
BE5-6646-H5 Front
BE5-6647-H5 Rear
Same shocks as the 1500...
IIRC, you're running the SJ 4.5" kit? You should be fine with the part #'s above. You can always contact Bilstein direct and get the compressed/extended length of that part #, and compare it to the shocks you have now.
Old Mar 15, 2005 | 05:48 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Sam's got a 800 number.....give him a shout.
He seems to be VERY knowledgable on the suspension side of things.
Old Mar 15, 2005 | 03:51 PM
phox_mulder's Avatar
Talked to Sam today and Bilstein doesn't make them "off the shelf"
They make them for the 1500, but he wouldn't sell them to be put on a 2500, especially one with all the front end weight we have.
He suggested calling Bilstein direct and asking them, then if they have a part number give him a call back and he'll get some pricing.
Being that Bilsteins aren't cheap to begin with, having them special ordered would be just a wee bit more than I want to spend at this time.
I'll check with the place I got my lift from and see what they offer, they might already have a deal with Bilstein for ones that will actually work.
phox
Old Mar 15, 2005 | 03:53 PM
He came right out and said he's never dealt with a truck lifted "as much as mine".
He is more a lowered truck kinda guy.
I didn't think mine was lifted "that much", and it looks lower and lower each day.
phox
Old Mar 15, 2005 | 05:33 PM
Cowhand's Avatar
phox
Jerry,
He sold 'em to Ed to put on his 3500......it's probably the same valving in a longer shock. Bilstein doesn't list anything for the 3500 in my info.
KORE is using an off the shelf 5100 for the fronts in his "Chase" kit, so as long as the length and stroke fit, the valving will be fine. Maybe Greg Boardman will chime in with a front part number......
Old Mar 15, 2005 | 05:37 PM
I'm going to call Bilsteins 800 number after I get some measurements.
I just find it odd that they list the same part number for the 1500 and the 2500 on the webpage.
phox
Old Mar 15, 2005 | 06:02 PM
Shovelhead's Avatar
My truck isn't 4X4 though so the longer shocks shouldn't be an issue.
The role of a shock isn't to support the weight as much as to control the harmonic oscillations of the suspension.
Ohhhh I Looooove big words.
now heading to www.dictionary.com to find out what I just said
Old Mar 15, 2005 | 10:13 PM
Cowhand's Avatar
Well said Ed.....
(Ed said "harmonic oscillations")
Don't need no shock to control MY harmonic oscillations....quite the contrary. As I get older, I'm more in need of the spring.....
Old Mar 22, 2005 | 07:02 PM
Shovelhead's Avatar
There was a brown box waiting for me when I got home.
My Bilsteins are here.
There are also already installed.
Front & Rears in just a touch over two hours.
Rears not too bad (except for the passanger's side lower, needed to drop one side of the sway bar to get the bolt past.)
Fronts....much more time consuming.
Sawzall used to cut about 4" off the dust covers, then vise grips on the shock shaft, 18mm socket & air ratchet to spin off the top nut.
Jack stand under frame & floor jack used to move the lower control arm up & down as needed to get the old shock out & the new one in.
PB Blaster to break the rust on the old hardware.
Real test tomorrow on the way to work.
pwr2tow
Feb 4, 2009 05:13 PM
pwr2tow
Feb 1, 2009 09:56 AM
tywebb3
Jun 23, 2006 11:30 PM
Wolff
23
Apr 10, 2005 12:46 AM
silverram323
Aug 8, 2003 03:09 PM
