Shift Kit???
Old Sep 8, 2005 | 06:17 PM
Tayloe08's Avatar
Shift Kit???
Sorry for ignorance but can you tell if a shift kit has been installed.....and how? Don't know what it is but mine shifts with a jerk going into reverse and drive from park. No BOMBing evidence from previous owner seems he took good care everything. I have heard this is my weakest part. However I do not haul a very lot very often. May sound silly I just want to take care of the trans so I know it is there if I need it!!(for work and play)Thanks in advance
Old Sep 8, 2005 | 06:19 PM
Tayloe08's Avatar
BTW I have had the truck almost 2 months now (LOVE IT!!!) and want to know of any trans maintance I should hove done. Has 82500 miles.
Old Sep 9, 2005 | 11:52 AM
vssman's Avatar
Hard shifting from park into reverse... What's the idle set at? A high idle will cause banging when shifting out of park. Also, worn u-joints or differential will do the same. A shift kit would most likely give you firm upshifts. Mine will shift very hard at light throttle upshifts (1st to 2nd especially).
Old Sep 9, 2005 | 12:31 PM
Bobcat698's Avatar
Mine engauges into drive and reverse from park firmly as well.. I have a transgo shift kit and I love it!
Old Sep 9, 2005 | 02:25 PM
justinp20012500's Avatar
A stall speed lower then stock will also cause a little firmer shift from park to drive and park to reverse.
A shift kit will do the same.
You can always grab a set of tranny gauges and do some line pressure tests,
Justin
shrmpboatcptn
Nov 16, 2010 06:46 AM
itr.#1446
Nov 9, 2008 09:03 PM
poogan
May 4, 2007 08:47 PM
Ilikebikes
Oct 11, 2006 07:56 PM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
