S400: 83mm Turbine 91mm Compressor
Schwitzer S400: 83mm Turbine 91mm Compressor
Can someone tell me what large deisel this is off of originally? Ive done some reaserch, and i see the s400 size is on the:
Detroit Diesel series 60 11.1L
Mack E7 series engines
CAT C-12
The question is what engine/horsepower did the S400 83/91mm turbo come on as the OEM turbocharger? I need to find and purchase that engine.
I need the engine just to spin the revolutionary oil-free turbocharger my company builds.
CAT C-12
I need to find ANY ENGINE with an s400 family turbo with the 91mm comp and the 83mm turbine. I have called millions of places and no one has a clue.
Are you telling me the seris 60 has those wheels or just an s400?
Look man, there is a possibility that i am not an idiot.
That dimension comes from the original Schwitzer blueprint for the machining of the wheel, im pretty sure its right. BUT just to be sure i put the turbine and shaft in a vee block with a tenth indicator on a height gauge on a granite surface plate, and sure enough 83mm. Go figure.
For YOUR information there are 4 main rotor groups for the S400 lineup
83/91
87/96
91/100
96/105
And if you want to go huge the biggest S600:
144mm Turbine / 158mm compressor
83/91
87/96
91/100
96/105
What's the BW PN# for that turbo? It looks like BW lists just the S60 (Detroit 60 Series) for that entire family. Perhaps a call to your local Detroit dealer would help? My local dealer was very happy to sell me any parts even though I only knew my s400 came from a 60 series Detriot. They also asked the application and were rather stumped when I said a Dodge with a CTD. Then the service manager drooled over the twins setup when I arrived later in the afternoon.
Here's from the BW website:
BW part no.: * 167735
OEM part no.: 23504966
Manufacturer: Detroit Diesel
Vehicle: Truck
Engine: S60
Power (KW/HP): 331/450
http://www.turbodriven.com/en/productsearch/index.asp
Here's my friendly neighborhood Detroit dealer if you'd like to call:
Detroit Diesel Engines
(614) 527-9400
3535 Parkway LN
Hilliard, OH 43026
brandon.
Vehicle: Truck
Engine: S60
(614) 527-9400
3535 Parkway LN
Hilliard, OH 43026
brandon.
Thank you very much brandon. I have gone that route, i called mack and cat dealers, but not DD. Perhaps that should be my next call. You happen to know what wheel sizes you have? Volute A/R?
I can find the turbo in various forms on the Mack E7 motor 1996 or later but i am unsure of the wheels for that engine.
Or a 1995-03 CAT C-12 engine, but i dont know if they ever came with the right size wheels. I have seen alot of pics of the 3406E and they all seem to have the 072N compressor volute.
Does anyone have a picture of a DD series 60 turbocharger? preferably mounted on the engine?
vr6, i found a large turbo on a mack engine at a local salvage yard. the turbo #'s are...
model sb3-085
Serial 631gc5134p4x
When researching the turbo i found a guy selling almost the same turbo serial # 631gc5134p5x... he claimed it had a 91mm compressor wheel. i can take a closer look at the engine or turbo at the yard if you tell me what to look for. meanwhile the link i had to that guys site seems to have gone dead... i can try to fing it if it would help.
model sb3-085
Serial 631gc5134p4x
Wow, first of all you guys are awsome.
I have the turbo, several of them in fact.
I need the engine, I think im going to take a "field trip" today to the mack dealer and do some under-hood snooping.
FYI that appears to be the correct compressor A/R. But curiously it has a reduced diameter air inlet, And a smaller turbine housing.
Im curious how you guys are finding out these model or serial numbers. My turbos came to me with experimental tags on them so i really have no clue as to what the model of turbocharger i have as a production unit. All of my wheels and turbine-shafts are custom cast for my special center section.
on here would be willing to try it in a twin setup.
