S300G Turbo
Old Jul 28, 2007 | 11:24 AM
Redliner's Avatar
S300G Turbo
This is sopposed to be like the B1 turbo, just wondering how much boost they are rated for??? Also is this a good upgrade from the stock HX35???
Old Jul 29, 2007 | 05:13 PM
Redliner's Avatar
Guess no one runs this at all??????????? ANY HELP PLEASE
Old Jul 29, 2007 | 05:49 PM
Phedge's Avatar
Yes it is just like the B1's. I ran one for 3 years and it done great on my 12 valve. With the pump adjustments and 370's I could make around 55psi with it. The only trouble I had was once I didn't let it cool after pullin and it burnt the bearings up. That was my fault though. The only reason I got rid of it was to go bigger. Hope this helps.
Old Jul 29, 2007 | 08:22 PM
Carp's Avatar
I am reall enjoying mine. The super B is a S300G.It has great spool as long as you have the fuel to turn it. It would fit well with what you have now. Definately outperforms the hx35 and BD has a "twin upgrade kit" to match up to it if you get to a point that you want more.
Old Jul 29, 2007 | 11:31 PM
Ph4tty's Avatar
Its close to the super b- BD does something to it, but I forget what HTT will have compressor, turbine, and housing upgrades availible if you need them.
Old Jul 30, 2007 | 10:33 AM
Redliner's Avatar
Thanks alot. I got one and just installed it. It did make a difference but not as dramatic as I thought it would.
roxxx
ABDTR #5
16
Mar 17, 2010 07:48 AM
Big Blue24
Dec 17, 2007 09:42 AM
FDPOWER
May 27, 2006 03:02 PM
NMCTD
Mar 29, 2006 12:38 PM
SuperDave4x4
22
Nov 16, 2005 06:10 PM
