???s from Cumminsdriver635
Old Jun 18, 2006 | 12:44 AM
Teddy Bear's Avatar
As some of you know Eric (cumminsdriver635) is gone for the summer to colorado to help harvest wheat on a 16000 acre farm. Me and him are 3rd cousins and are just about as close as brothers. Anyways, after he gets back from colorado his wallet should be padded quite well and hes wantin to spend a little bit of his hard earned money on another upgrade for his truck Was talkin him on the phone today and he was wanting me to make a post for him. Hes thinking about putting a set of 191's in but he's kinda worried about his EGTs being too high. His truck is a 94 auto with a triple disc goerend tc and transgo shift kit, 3kgsk, 0 plate, 16* timing, k&n cone filter, and 4 inch exhaust. He told me that he would really like for his EGTs to be below 1500* in a wide open pass in the 1/4. Right now with his mods his EGTs are at about 1300 at the end of the 1/4. He was just wanting to get some input from some of you guys on here. Also, what kind of RWHP gain can you expect from a set of 191s?
Old Jun 18, 2006 | 11:11 PM
joefarmer's Avatar
He went back to a 12cm housing, right? If so, I think that 191's would be enough fuel to consider turbo upgrades.
brandon.
Old Jun 19, 2006 | 12:13 AM
Teddy Bear's Avatar
Thanks for the reply joefarmer. I think hes got a 14 cm housing on there, but im not for sure. I forgot to put this in earlier, his truck does have the 160 pump and stock injectors.
Old Jun 19, 2006 | 08:07 AM
TxDiesel007's Avatar
with some 191's
hed be pushin the limits of a stocker perhaps, i guess what i would need to know is what boost numbers is he seein? he could block out the wastegate and use those 191 DV's and probably make it work... but he might risk grenading a turbo...
PS tell Eric i said hello...
Rick
Old Jun 19, 2006 | 03:23 PM
Teddy Bear's Avatar
Rick
Will do....
So do you think he'd be better of with 181s instead? What other suggestions might yall have for power upgrades?
Old Jun 20, 2006 | 06:39 AM
boughtadodge's Avatar
find a 215 pump and put on it he will be more happy with it. I tried 191's in my 160 pump and did not like how quick it would get real hot it did not give enough power for the heat that I gained. I bought my 215 pump for just a little more than what I paid for dv's and then sold the 160 for almost as much.
Old Jun 20, 2006 | 06:53 AM
MadGoat's Avatar
TB,
Tell him to get up off that wallet and get him some DV's, injectors, some timing & a turbo. Then let her ride .
Of course, shortly there after comes the need for head studs & gasket fire rings, a new tranny, etc...
Actually, I think he'd be OK with a set of 191's and the exhaust housing he has. As for EGT's, what's he looking at that for anyways??? Mine never go over 1500deg , at least that's as far as the gauge reads anyways???
Old Jun 21, 2006 | 12:12 AM
Teddy Bear's Avatar
with some 191's
Rick
So you have a 215 pump with a 4KGSK, 100 plate, 370s, AND 191s being cooled by a HX35, and youre worried about eric's EGTs???
Old Jun 21, 2006 | 04:11 PM
Teddy Bear's Avatar
I talked to eric today and he said his truck has the 16cm housing on it right now. I think he can make 30-35 pounds right now
Old Jun 21, 2006 | 10:52 PM
Hmm
thats about the limit of the stocker, I can make about 44 psi on mine and clutch went boom, aint done that again I think 181's will suit him just fine. I might have a set for him soon enough, ;-)
Rick
Old Jun 21, 2006 | 10:56 PM
displacedtexan's Avatar
Hmm
Rick
So I guess you got a job? Since you need air, and a DD, and you seem to be in the market for lazer cuts and 215's
You're my hero!
Old Jun 22, 2006 | 09:34 AM
You're my hero!
I still gotta pass my background search
shouldnt be an problem i hope, and i must retake the hearing part of the physical, inconsistent results. so im told, (that reminds me i have a call to make) I got an insurance check but ima put it to use on what the truck needs, more than just what i want. Mark my words tho when i get on with BP if i do (pray for me) I will get me a dual disk and probably rips twins, are lookin as the best right now. Much better price and better performance than PDR...
till then, i sold some 215's and i have 191s, laser cuts wont come till much later when i have air...
Rick
Old Jun 22, 2006 | 02:33 PM
Rick
That's cool, wish you the best with the retesting. And you ought to pass the background test. I'm hoping you get the BP job. Good luck buddy.
