Rough Idle with Jammer IV's anyone?
For some reason, my idle is getting rougher and rougher. I just wondered if anyone was running these injectors and have the same observations. Not that it bothers me, it just lopes real bad when feathering the clutch in reverse. I have checked all my lines and intake, everything seems to be tight and good to go. Any advice? I'm watching my fuel gauge real tight. I hope that isn't the problem. I have 13-14 PSI at idle. I only see 3 or 4 at WOT!!!
No. I didn't go to the trouble to test them. I just swapped them truck to truck, injector and all. I got them sooooo cheap, I just put them in and went. I wish I could afford Machs, but I blew my wallet on all the other stuff I put on here. Maybe next Christmas the old lady will buy me a nice set! Don't get me wrong, I do like the Jammers. They run great, I just wondered if there were any tricks to smooth out the idle, it don't hurt a thing.
First off you are flirting with a $1,000 VP44 running 3-4psi at WOT...keep the box turned down, or get a pusher pump on there ASAP.
secondly, the jammers are known to lope like that, but one thing you might want to check thats easy to do is pull the valve cover and check the torque on the injector hold down tabs. i had one come loose after i installed my DD3's a few years back, and that caused a rough idle. i checked the torque on them and then it ran alot better.
2) Thanks for the advice. I'll check the torque on them this week.
Thanks!
banks twinram
May 18, 2010 08:10 PM
xOmertAx
20
Feb 17, 2007 09:52 PM
Timmay2
Aug 4, 2006 12:38 AM
Derek Roch
Aug 3, 2006 10:02 AM
natlchamp2k4
16
Feb 22, 2006 03:39 PM
