Replacement clutch?
Old Jun 5, 2013 | 10:49 AM
cvcook's Avatar
Replacement clutch?
What's a good clutch replacement for a 5600? Stock with a edge EZ chip. Max towing is about 7k pounds
Old Jun 5, 2013 | 11:05 AM
cvcook's Avatar
Truck is a 02 4WD
Old Jun 5, 2013 | 11:32 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
The guys here really like the South Bend clutch...I've had no problems with mine..
Old Jun 5, 2013 | 11:42 AM
nkennedy's Avatar
The factory LUK clutch ain't bad for stock HP.
Old Jun 5, 2013 | 05:48 PM
lovinCTD59's Avatar
I really like my south bend con ofe. It takes everything I have thrown at it. I have grown to like the crisp engagement too
Old Jun 5, 2013 | 07:21 PM
cvcook's Avatar
Would a south bend last longer than a stocker?
Old Jun 5, 2013 | 07:58 PM
totalloser's Avatar
I wen't with Valair. I wrinkled the hub on my LUK. It didn't slip, it tweaked. I was unimpressed. The Valair has held up fine, didn't cost much more than stock and is holding significantly more HP than specced for. http://valairinc.com/performance/24nv5600.html
I got the HD spring hub one with organic friction for durability and smooth engagement- the higher HP exotic friction discs are either grabby or wear out quickly.
Old Jun 5, 2013 | 09:26 PM
lovinCTD59's Avatar
Yes and no. Any clutch you go with will not last forever. Its kinda like expecting brake pads and rotors to last a lifetime. That being said I believe a SB clutch will outlast any oem clutch as long as your not overpowering the clutch and treat it right. I would call peter at south bend and tell him what you will be doing with the truck and he can help you decide. I have no experience with valair so I'm not saying they are a lesser product.
Removing and installing a NV5600 can be a chore, many will tell you don't cheap out on a clutch in these trucks.
Old Jun 7, 2013 | 11:34 AM
SIXSLUG's Avatar
I went with a SB Con OFE after taking into consideration what I am really going to use my truck for. It has been a great clutch with smooth engagement and doesn't balk at the occasional 12K trailer I pull....
snakefarmer
Dec 23, 2004 10:11 AM
Paintpusher
Jun 25, 2004 06:05 PM
joking
Jun 2, 2004 05:36 PM
snow104
Sep 13, 2003 03:12 PM
joel
May 7, 2003 10:12 PM
