Remove heater grid, more power?
Old Nov 6, 2004 | 11:34 AM
Jambbii's Avatar
Just wondering if I could gut the grid to get more power. It never gets that cold here so I was wondering if anyone has ever done it?
Old Nov 6, 2004 | 11:45 AM
Bob Wagner's Avatar
Yes, It is done and here is the block to replace the grid heater
more air is good
Old Nov 6, 2004 | 12:10 PM
BigBlue's Avatar
I wouldn't screw with it. It's not hurting you any. Even guys pushing big boost are leaving them in.
Old Nov 7, 2004 | 10:58 AM
Jambbii's Avatar
I was just looking for some real cheap power.
Thanks for the replies
Old Nov 7, 2004 | 12:58 PM
BigBlue's Avatar
You might gain .0000000000001 hp from it if you were pushing 150psi.
Old Nov 8, 2004 | 11:09 AM
dodgeman01's Avatar
The biggest problem with the grid heaters is the seals tend to blow out both top or bottom. I have lost 3 around 50psi of boost. even if you replace the grid heaters with that plate you will still have the same problem. If you really want to get rid of it your best bet it to have or make a new air intake horn that bolts directly to the engine with no spacer or adapter.
DM01
Old Nov 12, 2004 | 08:02 PM
MikeR's Avatar
dodgeman,
Haisley Machine makes copper gaskets, you should look into them.
Jambbii,
I dunno if it made any difference in my '98 12v. I installed a Twin-Ram manifold and completely gutted the heater grids out of mine. I wanted the least restriction I could get.
SpeedyWS6
15
Feb 2, 2011 07:22 PM
canadakonrad
Dec 1, 2010 08:41 PM
tesla440
23
Oct 5, 2009 06:05 AM
Ramrod90
Feb 3, 2009 07:39 AM
taildragger
Dec 4, 2006 10:00 AM
