Recommended programmer
Old Nov 10, 2012 | 09:10 PM
rovpilot26's Avatar
I have been looking at the Edge Juice with attitude CTS because it also has the added gauges for my 01 24valve
Any recommendations on this or a better alternative
Old Nov 11, 2012 | 08:44 PM
high bid's Avatar
Or Quadzilla adrenaline. I'd make sure you have a fuel psi gauge and/or an aftermarket LP. No less than 8psi fuel or you'll kill the vp pretty quick. Many other things to consider also but reading on here will help.
Old Nov 11, 2012 | 09:31 PM
rovpilot26's Avatar
Does the Juice CTS have the ability to show fuel pressure? That was part of the reason I was leaning towards it since it has built in gauges. Definitely plan on either an FASS or Airdog 95, unless that wont be enough and I need to go with a larger lift pump
Old Nov 12, 2012 | 09:18 PM
high bid's Avatar
I'd ck to confirm about fp on the juice cts. FP gauge on a vp44 truck is prob the single most important gauge. Yes Fass or AD will work well to supply adequate FP but there are lots of other less expensive options that have proven to work well.
Old Nov 15, 2012 | 12:39 AM
rovpilot26's Avatar
FASS and AD are the only two that I keep seeing over and over. If there are economical options I'd love to know about them.
Old Nov 16, 2012 | 10:56 AM
high bid's Avatar
I run a spin-on baldwin fuel filter to a holley blue ($125)LP back by the tank inliine to a factory replacement from Rock Auto($100). Based on the psi, one could use the Rock Auto LP and be good w/fuel psi. My setup is prob overkill but I know I won't have a fuel issue.
Rock Auto -AIRTEX Part # E7153
Old Nov 19, 2012 | 01:07 PM
Sea:\>Drive's Avatar
While I appreciate high bid's concern for your wallet - been there, done that, and read way too many stories on this forum over the years. I had a Holley Blue, Black, and Carter replacements - then I put on a real fuel pump and haven't looked back for the last few years....go with your original idea. I could have saved $$$ if I did right the 1st time.
DYEVOUT
Aug 24, 2003 07:01 PM
DYEVOUT
Aug 19, 2003 05:22 AM
finallydiesel
Aug 9, 2003 08:22 PM
Paul S.
Apr 22, 2003 08:22 AM
Maddog
Jan 3, 2003 06:17 PM
