Rear Axle Options for Sled Pulling
Old Apr 22, 2006 | 11:05 PM
  #31
Bobcat698's Avatar
Originally Posted by CTD NUT
You could use a DRW D80 but the WMS is wider than a SRW but the SRW wheels will bolt on. If you came across one, a cab and chassis DRW D80 might fit the bill since it is closer to the WMS width of a SRW.
How much wider are we talking? Currently, the front tires stick out past the truck just a TAD more than the rear wheels.. Is it going to be quite noticable?
I found a D80 on a DRW truck pretty close, and I found a D80 on a cab and chassis DRW farther away.. Is it that big of a deal if I can get both for similar prices.
Thanks!
Old Apr 23, 2006 | 01:33 PM
  #32
Paul Winey's Avatar
Not to hijack thread but I'm in need of rebuilding my clutch packs on the D70. I've tried adding some additive and don't want to risk a complete replacement. The shop looking at doing the clutch job talked about replacing with a Detroit Locker type limited slip. How do these hold up and would I be better off replacing stock clutch packs and saving $ for some stronger axles. Or should I save $ and do both locker and axles. I also plan for truck pulling this year.
Paul
Old Apr 24, 2006 | 12:30 AM
  #33
zstroken's Avatar
Muted User
Dana 80
I have a Cab and chassis Dana 80 in my truck now. About 1.5" narrow per side(3" total) than the Dana 80SRW. I would guess that the DRW dana 80 would be about 3" wider overal maybe a little more than the SRW. Only thing bad about the cab and chassis DRW end is that the Drums are really mounted inward, so from the rear of the truck you can almost see the complete width of the drum outside of the tire. If you look at the axle with the tire off you can see what I mean. You also have to have like a 7" center cap for it. I put my old centers back on and tore one up. I have seen probably 3 or 4 Dana 70's break. 3 of them have been the ring/pinion gear.
coreydr2003
MODTR #30
27
Oct 1, 2009 04:56 PM
UnrulyNFS
Competition / Pulls / OffRoad
Jun 24, 2006 03:26 PM
Bobcat698
Apr 22, 2006 12:39 PM
JMull
Aug 12, 2003 01:32 PM
PourinDiesel
Nov 10, 2002 07:20 PM
