Rear Axle Options for Sled Pulling
Old Mar 29, 2006 | 04:42 PM
Bobcat698's Avatar
Originally Posted by srt20
hey do you plan on coming down to southern WI at all? I cant help ya as far as what rear to run. But we have a truck pullers club down here that has a pretty good show, badger truck pullers assoc. or something like that. there is a guy with a really sweet third gen. that does well, but he wrecks ujoints, driveshafts and rear ends alot. its his daily driver too. be cool for you to come down and try to beat him. get a second gen. back in first place! Bret
p.s. just looked at pics of your ride... very sweet!!
Hi, I plan to come to southern wisconsin and pulling with the badger pullers, should be a good time!
The furthest south I pulled last year, in Wisconsin, was at West Bend. I also pulled in Fon Du Lac.
The pull in Yorkville IL was a lot of fun too.
Old Mar 29, 2006 | 04:45 PM
Bobcat698's Avatar
Thanks for the input so far..
Still waiting for an answer on the DRW rear axles.. Can those be used as SRW or is it a pain in the butt?
Old Mar 29, 2006 | 04:51 PM
Mcmopar's Avatar
If the wheel mounting surface to WMS is the same, and the spring perch mounting is the same you can use it.
Old Mar 29, 2006 | 04:55 PM
Bobcat698's Avatar
Originally Posted by Crimedog
Hey, how close is Amherst to the MN border by the way? I might be heading across the river to a pull or two this summer...
Pretty far, Look Here
But I will be at some northwest Wisconsin pulls too.. Basically I'll hit every one I that I can!
Old Mar 29, 2006 | 05:54 PM
CTD NUT's Avatar
You could use a DRW D80 but the WMS is wider than a SRW but the SRW wheels will bolt on. If you came across one, a cab and chassis DRW D80 might fit the bill since it is closer to the WMS width of a SRW.
Old Mar 29, 2006 | 06:49 PM
Diesel-Dan's Avatar
What about a planetary Rear axle....say out of like a 9000 series Deere?? haha...that would be awesome!
Old Mar 29, 2006 | 07:04 PM
Bobcat698's Avatar
Needs to be streetable
Also can be no bigger than what came in a 1 ton truck so I can run in the DHRA street class.
Old Mar 29, 2006 | 07:14 PM
GlennRMK's Avatar
Dana 80 is only a .5" bigger ring gear. Its an 11" versus the 10.5" Dana 70.
But as mentioned, both have the 35 spline 1.5" shafts
The big superdutys, like 450/550s have the 37 spline axles. But the metric bolt pattern.
I would agree with these guys and say just upgrade the shafts, and I doubt you will break the ring gear.
Old Mar 29, 2006 | 07:18 PM
Willy91's Avatar
All we did was upgrade shafts and it's been fine so far.
Old Mar 29, 2006 | 08:09 PM
Bobcat698's Avatar
I'm not hurting anything then by leaving it together until I break a shaft, right?
You think at 500RWHP and truck pulling without letting out of the throttle EVER I wouldn't break the ring and pinion?
I'd think it'd shatter when it hops..
Old Mar 29, 2006 | 08:13 PM
Willy91's Avatar
We haven't broken it yet, and have hopped real bad a couple of times. I have only one speed while pulling....Through the floor.
Old Mar 29, 2006 | 08:45 PM
TravisG's Avatar
What ya need there is a set of traction bars to keep from hoppin. Oh yeah and get the cylinder head back on. Just kiddin ya Garret. See ya Saturday.
Old Mar 29, 2006 | 09:15 PM
59Dsul's Avatar
I saw a couple of 70's grenade this year. Both times the pinion sheared. The difference in size between a 70 and 80 pinion is pretty big.
Old Mar 30, 2006 | 06:01 AM
CTD NUT's Avatar
Agreed, don't be fooled by the 1/2" difference in ring gear size......the rest of the components in the D80 are massive compared to the D70. The D80 pinion, pinion and carrier bearings and the carrier itself are much larger and capable of handling much higher torque loading than the D70.
Old Mar 31, 2006 | 01:48 AM
Tate's Avatar
I've also hear that the axle out of a 4WD F-Superduty truck is a Dana 80 setup as well, and has the same bolt pattern.
The F-superduty trucks only came in 2wd (still had asolid front axle though), and ran a 37 spline d80 rear. But they had a 10 lug bolt pattern, not the standard 8. May as well just get a 37 spline carrier and axles and through them in the dodge d80.
