raptor fuel pump
Old Feb 14, 2009 | 10:05 AM
dodge_24's Avatar
raptor fuel pump
just to let everybody know i have had the raptor 100 for about two months
its been working great i have 16-17 at idle and 13 psi at full throttle better acceleration i have not figure my mileage i was getting 21 before the pump
so far happy with the pump
thanks for the help guys
Old Feb 14, 2009 | 10:15 AM
Snoxracer's Avatar
Yeah they seem to be a great pump, I've installed 5 raptors and not a problem with any.
Old Feb 14, 2009 | 05:59 PM
JoeCanuck's Avatar
Mine has been working reliably for about 6 months or so. The only thing I've done is boost the pressure a bit...simple as turning a screw.
Old Feb 15, 2009 | 10:42 AM
AllanP's Avatar
I have been very happy with mine so far. I did however find that my adjustment screw had rusted stuck. I had to pull it out and put it in a vise to loosen it up. I have contacted them and they should send me a new screw as soon as I send them my serial #. Other than that its been great.
Old Feb 16, 2009 | 11:48 AM
Dazeys's Avatar
Buddies Raptor 150 blew the 25 amp fuse in the wire harness. Replaced it and it blew again. Put in a new fuse and it ran long enough to drive on a trailer and get it to to my shop. Started up to drive off the trailer once he got it there. I haven't been to the shop to check it out yet.
Old Feb 16, 2009 | 01:30 PM
JoeCanuck's Avatar
If you don't mind, let us know what you find out.
Old Feb 17, 2009 | 03:21 PM
Dazeys's Avatar
It blew another 25 AMP fuse so I put in a 30AMP curcuit breaker and it runs but the wires are getting hot. Checked the pump and it is to hot to touch. Shut the truck off removed the relay and ran a jumper from the fuse to yellow wire going to the pump to bypas the relay. Pump runs to hot to touch still.
Old Feb 17, 2009 | 07:59 PM
JoeCanuck's Avatar
It's definitely the pump. Is it still pumping and producing any volume and/or pressure? I'm wondering if it might be clogged or jammed.
Old Feb 18, 2009 | 09:23 AM
Dazeys's Avatar
I was thinking the same thing. I need to check for a restiction next.
RAM2940
Apr 6, 2008 06:07 PM
zchornyak
Apr 1, 2008 04:23 PM
03veggieram
Mar 16, 2008 11:42 PM
MATTIEBOB
Feb 23, 2008 07:27 PM
84mphcdt
16
Dec 19, 2007 11:31 AM
