Race Box Beta Testing!!!!!!!!!!!!!
Big High Idle problem just occured. Idling great but with the grid heaters kicking in the idle is ALL over the board. Sometimes the idle even dropped back down to 850 rpm and then back to 1200?
Bryan
But with the reading being taken at the pump if 19psi is present then there should be plenty of fuel avail... Now if most of that is bypassing the 14psi overflow... I guess that is possible.. I've always wanted to check flow out of that line!
I"m thinking of the internal charge pump.. there is a regulator for its pressure..
Charge pump
Pressure regulator... (The piece on the upper right with the red dot..)
[img] http://www.turbodieselregister.com/u...=17237&width=0 [/img]
Its been a few years since I made this pic .. I think everything is correct.
Well.. I can't get the pics out of my TDR albums...
Charge pump
Personally, going by how the Adrenaline reacts on my truck, I don't think Quad is draining the rotor dry...yet... I have a Redline box, and when it drains the rotor the results are completely different. I think there is still a lot to be gained with this box. We need to give Quad sometime, before we start redesigning the VP44. On my truck it has all the indications of having to much advance on the top levels, at higher rpm. I think if we give Quad more time he will be able to coax more fuel out of the VP44.
Just my $.02 worth...
Paul
Paul
I think there could potentially be an Auto and a Manual program. Between shifts on a manual, it is my contention that the VP has a chance to catch up so a little so more aggressive fueling can be tolerated without draining the VP. On an Automatic truck hopefully he can find a happy medium to stretch the fuel so it doesn't drain it until you hit the traps with the constant boost and fueling the Auto demands. That may be difficult to achieve though with different set ups.
OK so many things i guess i got lost but whats the newest program that has been sent out? I got the newest one like a weekago and still having TT just wondering what the newest program was?
RJ
Paul
