Quick question... Pyro Gauge turn on... (I used the 20amp fuse for ABS)
Old Apr 12, 2007 | 07:55 PM
Common's Avatar
Is that OK?
Or is there another way I should do it?
Old Apr 12, 2007 | 08:12 PM
Common's Avatar
Quick, before I burn something
Old Apr 13, 2007 | 06:06 AM
Common's Avatar
I'm assuming its ok since nobody said "NO"?
Old Apr 13, 2007 | 03:05 PM
cheapskate's Avatar
if it works without blowing the fuse, my guess is that it will be fine. i hooked mine the the hot wire going to the cab clearance lights. i doubt that gauge draws enough juice to really cause any problems.
Old Apr 13, 2007 | 11:13 PM
zulusafari's Avatar
I powered mine by a large orange wire under the steering column, that was hot in the IGN ON position. I don't fully remember why, but after 3+ years, it seems to be great. I also used that wire for my low fuel pressure warning light power. Ran the hot wire to the LED, then the ground wire to the sensor switch at my VP. Works great and cost me $37 bucks!
bigjohn92
Nov 25, 2010 01:32 PM
Lrdchaos
Jul 15, 2006 01:02 PM
Evildiesel
Nov 18, 2005 04:12 PM
RenegadeT
May 3, 2005 07:08 AM
