Quick help needed on rear axle upgrade
Old Nov 21, 2006 | 09:49 PM
dieselrob's Avatar
Ok well i found out today i was sent the wrong locker for my truck. Instead of the 32 spline on on the order sheet i was sent a 35 spline detroit. My ? is can i pick up the 35 spline upgrade axles from say eep or someone and just throw them in with the locker? Is there anything on the out side hub where the axle flange is that needs to be changed too? Or is it a straight bolt up process with the 35 spline axles and a 35 spline carrier. I also was thinking do dana 80s in the trucks with standards are they 35spline axles? Need some quick help cause the holiday is coming fast. Thanks guys
Rob
Old Nov 21, 2006 | 10:09 PM
Tate's Avatar
The D80's come with 35 splines, and I'd almost garauntee that the axle flanges are the same. I'd say phone up a parts place, see if thay can give you some measurements on axle shaft lengths between the 70 and 80, then go to the junkyards.
Machinos
Aug 30, 2009 07:21 PM
pulltilbroke
Jun 8, 2009 08:04 PM
whttacoma
Nov 17, 2007 08:41 PM
ataboy9026
Dec 6, 2006 09:33 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
