Question to all 12 valve pro's?
I have my siq filled out to current stats. I am wanting to go with the DDP stage 3's and a big single( still researching turbo, want something from HTT ) both at the same time in a few month's. I tow 7,000 lbs in Florida bout 2 days a week. Will this be an ok setup? And can I get close to 450 or 500 RWHP? Please any advice, have been sifting threads for days
If all he wants is 450-500 he doesn't need anything bigger than a 62mm turbo IMO. And my injectors are bigger than DDP4's and I have towed 20k-ish with them, just switch to valet mode and off ya go.
Also...with a 64mm charger, you will have some surge to deal with IMHO...not much at 7K lbs, but you might get some! Keep the RPM up a bit if you do
I almost don't consider 7K towing...my trailer weighs more than that empty
Chris
Chris
I know a few guys that only run a 62 MM wheel that tow quite a bit of weight w/o haveing a whole lot of problems with heat. On some long steep hills they get hot but driveing around Ohio and KY they do just fine with the 62 wheel.
DM01
DM01
Schoust good luck with the turbo and keep us informed, And Im not necessarily limiting myself to 500. I just want the turbo and injector upgrade to be the end of my upgrades, but If I can run some big injectors and still be cool Im goin for it
. And I agree 7,000# isn't hauling its just smoothin out the ride of the dually
but I wanna make sure I give all the info I can so I get the right advice. So what setup do you guys think? as far as injectors and turbo? I've got 2 months to research.
cb's dodge
28
Oct 6, 2008 07:14 AM
crossy
Oct 18, 2007 08:48 AM
wreedCTD
13
Apr 26, 2007 09:55 PM
