Question about my setup
Old Jan 2, 2010 | 03:12 PM
tractorguyacb's Avatar
I have a 2000 24valve a quadzilla xzt, bd 75 horse injectors, and a bd super b single turbo. What kind of boost should i be seeing? With the wastegate line clamped i can only get about 33 pounds max. I have done a boost leak test with an adapter that i made. I can hear no leaks in the intercooler or boots. I think i should be seeing more boost, or am i thinking too high of my setup. Any input would be appreciated.
Old Jan 2, 2010 | 05:12 PM
Clunk's Avatar
You should see more boost than that. Are you running out of fuel? What's your lift pump fuel pressure?
Old Jan 2, 2010 | 07:36 PM
lift pump pressure is 13 psi WOT 15-18 at idle. It is a raptor RP150. I am with you in thinking that i should be seeing more, however i do not know what is wrong.
Old Jan 3, 2010 | 07:46 AM
Clunk's Avatar
Are you tapped to the injector pump wire?
Are you running a 4" exhaust system?
Old Jan 3, 2010 | 09:03 AM
RowJ's Avatar
Originally Posted by tractorguyacb
...I think i should be seeing more boost, or am i thinking too high of my setup. Any input would be appreciated.
At about 350 hp (max), with a great turbo for that level, I'm not sure you should see much more boost.
At 350 hp, with the factory HY-35, I think I pulled 38 psi or so. (much smaller turbo). How are EGT's at WOT. If not high, you're in good shape.
RJ
Old Jan 3, 2010 | 09:23 AM
at WOT my EGTS are around 1050. Thanks for your input
Old Jan 3, 2010 | 10:45 AM
RowJ's Avatar
That turbo moves a lot of air for it's size, as evidenced by your egt's.
Room to grow, hp-wise, which is excellent. If you had a leak, your egt's would be much higher.
Not maxing out your turbo (about 40 psi) means cooler, denser air charge..... Excellent.
RJ
Old Jan 4, 2010 | 07:19 PM
DodgenIt's Avatar
X2. I have been impressed with my super B so far. With whats in my sig... playin around on the freeway with goin WOT, highest temp ive seen is 1204 at 35 lbs boost.
Which makes me exstatic.
Id say as long as you have the trans to hold it, IMO, your good to look at a bigger chip or injectors if your wantin more power.
ryanihf250
Jan 17, 2008 02:58 PM
GaCamper
Apr 30, 2006 02:16 AM
LanceD
Oct 20, 2004 07:55 PM
hellotbone
18
Jun 25, 2003 01:16 PM
