quadzilla power
Old Aug 1, 2007 | 06:47 PM
Floorman's Avatar
quadzilla power
does anyone know what the xillaraider puts to the ground for hp and torque? and if these boxes can have programs written for them thanks
Old Aug 2, 2007 | 07:34 PM
Floorman's Avatar
38 views and no answer wow
Old Aug 2, 2007 | 07:44 PM
afoulk's Avatar
their site says it'll add up to 120hp/325ft lbs. If your looking into one of their boxes, you might wanna hold off. They're currently working on a new "race" box that they claim will fuel similar to a smarty stacked with something else (tst,edge comp, etc. ) and you will be able to raise the rev limit to 4k rpms. Thats what I'm holding out for The power will supposedly be higher than the current 120hp that everyone else seems to be stuck at.
Old Aug 2, 2007 | 10:25 PM
qzilla's Avatar
It really makes big difference on what pump you have. Its output is very similar to a COMP. On dyno runs they mimic each other to peak and then as the Comp starts falling off around 2700 rpm we continue to fuel. That is the main difference in power curves.
I threw the Comp in there as I am sure you have seen plenty of dyno numbers from it.
I have seen the 120hp box put down anywhere from 90hp to 140hp based on the pump and other mods done to the truck. On a stock SO pump with a clutch that is not slipping it puts down right at 120hp if not 1 or 2 more.
Old Aug 3, 2007 | 08:13 PM
Floorman's Avatar
great thanks im running it now and love the power but want more
mopar440cu
Nov 21, 2015 08:39 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
RockGuy82
13
Aug 24, 2006 06:33 PM
dssimecek
Sep 25, 2005 07:34 AM
