Quadzilla 3-stage box?
Old Nov 8, 2005 | 05:59 AM
Rauschbo's Avatar
I am thinking of adding a performance chip, and found the 3-step adjustable Quadzilla module advertised on this site (0-35-70 hp box, cab adjustable).
I have a stock auto-tranny in my truck with about 20k miles on it (the last one went at 96K); Other than beefing up the fueling system - probably with a FASS - I've no plans to mod the truck
Is this box a pretty good set-up, and do I need to worry about hammering the transmission? I don't see any need for hitting the top adjustment on the box, and am hoping to get increased fuel efficiency from the lowest setting. AND - does this box have an "off" so I can run with OEM performance, turning the box on only when "needed"?
Thx -
Rauschbo
Old Nov 8, 2005 | 07:21 AM
Ph4tty's Avatar
Originally Posted by Rauschbo
0-35-70 hp box......
snip
I think that the 0 in 0-35-70 is the oem setting
Old Nov 8, 2005 | 08:32 AM
RowJ's Avatar
I Agree! "0" is probably boost fooler only...which is as good, actually better, than off, since your turbo is still reasonably efficient up to 32-35 psi boost.
Based on expirience with the Egde EZ (65 hp) I believe the middle setting will not hurt your tranny, if it's in good shape. May be ok on high also?
RJ
Old Nov 9, 2005 | 06:07 AM
Rauschbo's Avatar
I've read of tranny pressure-boost mods that can be added (more for the TC than anything else); Would something like this assist in transmission life? What else would fail fisrt (other than the cheap, pressed in pump bushing that failed on my last transmission)?
Coal Train
Jan 12, 2007 10:17 AM
Doubleover
Apr 21, 2006 02:38 AM
052500#1
13
Jan 6, 2006 03:27 PM
timb
Aug 19, 2005 10:16 PM
