Pyro / Towing question
Old Apr 22, 2007 | 09:59 PM
Fishjager's Avatar
I noticed while towing my boat today (4700lbs) at 55-60mps that the pyro was up around 1100 on slight hills. Is that normal? I am new to diesel and
the cummins. It cooled down on level spots to about 7-800. What is the temp that I should worry at?
My truck does not have a tow button, but it does have a O/D on off button.What should I tow in O/D off, or O/D off and slip into overdrive when cruising at 60mph?
My transmission is a DTS automatic, built by those guys up in Chilliwack BC.
Need some help on this one
Old Apr 22, 2007 | 10:29 PM
Buckshotram's Avatar
its normal for your egt's to rise while climbing a hill. Dont let it get above 1250 deg for more than a couple seconds. Dont lug the truck while pulling.
Old Apr 23, 2007 | 04:19 AM
HOHN's Avatar
Your truck can handle 1250 all day long. No sweat for what you're seeing.
jh
Old Apr 23, 2007 | 06:54 AM
2500CTD's Avatar
EGT's will go up on a hill if you let the engine drop in RPM's. Like on steeper hills downshift get the rpm's up to around 2000-2200 and the egts will drop, as long as up dont have to keep it on the floor to maintain those rpms on a given hill.
alltimelow1
Mar 6, 2005 02:49 PM
big pappa
Feb 27, 2005 10:00 PM
lovemysan
Jan 12, 2005 05:19 PM
rjordan
May 4, 2004 01:55 AM
CTD99
May 19, 2003 10:24 AM
