Being Stupid Sucks
Old Apr 14, 2007 | 08:32 PM
YZ3500F's Avatar
Being Stupid Sucks
I was out messin around with my tuck doin burnouts well i just found out that a 2002 dodge cummins with the edge with attitude on level 6 and BD 150 hp injectors and 35" tires ruin a clutch real quick i think my southbend clutch is fryed im such a idot. Has anyone had any excprice with a dual disk clutch and what do they cost. And how do they drive
Old Apr 14, 2007 | 10:53 PM
Phedge's Avatar
I have a south bend dd 3600lb clutch in mine and I love it. They are a little noisy with pedal pressed down. They will hold just about anything. They say the new one south bend has out now don't have any noise to it. I paid around $1500 a couple of years ago for the clutch and another $500 for the bigger input shaft on my 5 spd. There are others out there but not sure about them this is the only one I have tried. I have pulled with it the last few years and it is still going with 50,000 miles on it. The pedal is a little stiffer though but that didn't bother me.
Old Apr 15, 2007 | 03:35 AM
BigBlue's Avatar
What style of southbend clutch?
Old Apr 15, 2007 | 02:56 PM
YZ3500F's Avatar
i think the CON OF it was the 550 horepower one
Old Apr 15, 2007 | 04:21 PM
TheBigNasty's Avatar
That would be the FE. Both sides are ferramic faced.
Old Apr 16, 2007 | 06:51 AM
YZ3500F's Avatar
my buddy dosnt think its the actuall clutch plate he thinks its sumtin else. D
Dose my truck even come close to 550 horepower?
Old Apr 16, 2007 | 07:06 AM
belgianmagic's Avatar
there ain't anything that will just 'SLIP except the clutch... you break anything else ...there is a bang, ... then you stop
and you really should be able to smell the clutch if you burned it
Old Apr 16, 2007 | 07:57 AM
SilverSootXpres's Avatar
I'm running the Southbend 3600# Street Comp 12CB (650hp).
Absolutely 100% satisfied with mine. Easy to back up to trailers (Not graby). I do a few sled pulls with it each summer, pedal pressure is firm, but not heavy.
It makes a little noise idling in neutral, but nothing drowning.
The hydraulic upgrade isn't required on this clutch on an 02', but I believe any bigger plate load will require the upgrade.
Old Apr 17, 2007 | 07:39 AM
BCSCUMMINS's Avatar
No your truck is not at 550hp. What makes you think that your clutch is trashed?
Old Apr 17, 2007 | 05:11 PM
YZ3500F's Avatar
you cant even get it in to gear the only way to drive in is to with out the clutch
Old Apr 17, 2007 | 05:12 PM
YZ3500F's Avatar
you cant even get it in to gear the only way to drive in is to shift with out the clutch
Old Apr 17, 2007 | 06:29 PM
PowrStorkthsRam's Avatar
OK hears one 4 yal. i got an 02 auto with the big hoss chip (the stuff in my sig) and i cannot even do a burnout! it i poert break, the motor will rev up to about 2k rpm of so with a little lite smoke and thats it. WHAT UP WITH THAT?
Old Apr 17, 2007 | 06:36 PM
HOHN's Avatar
It's called a weak tranny, specifically the Torque Converter.
Old Apr 17, 2007 | 06:51 PM
Matt Lambrech's Avatar
I just had the same problem, could not get in gear, mine was the pilot shaft bushing was wiped.
Old Apr 17, 2007 | 08:30 PM
taken5875's Avatar
In response to you not being able to do a burn out have you tried smashing the go peddle then letting the truck move about a foot or so then stand on the brake if that doesn't do it check under the hood you might have a power stroke seriously my 01 does the same thing if the computer reads 0 speed then it will defuel I think at like 10psi but if you let it move a bit you can fool it and you will be able to burn em off.
