pyro?
basicaly it gives you a more accurate reading of how hot the exhaust is that is going into your turbo so that you wont cause any damge to it or your engine. It is very easy to max your egt after you start bombing these engines so if you can keep a more accurate watch on your egt the better.
Well when you put Chips and injectors in these trucks they will run real hot EGT's if not enough air (larger turbo), and your big truck engines are just setup with factory fueling so heat shouldn't be a problem. Unless your engine is turned up, then it would be important to have a EGT guage pre turbo in your big truck.
FiverBob
24
Nov 27, 2002 03:32 PM
