Pump Relocation
Old Nov 27, 2006 | 06:56 PM
RAFTEN's Avatar
Pump Relocation
So I ordered the Vulcan kit from Geno's that moves the LP back by the pump. Before I install it I wanted to ask of those who did if they are satisifed with the results. Or, would they have rather installed a pusher in addition to a stock location? I guess when the kit gets here I will decide what additional fittings I would need to have a two pump system if I decide to do it. Could just send it back and order the pusher kit directly from Vulcan.
This last weekend my power dropped of climbing out of a lake basin so it looks like another LP is due to be installed. It might have something to do with the bio diesel I run as it was cold the night before but I have had enough LP's go to know the symptions.
Old Nov 27, 2006 | 07:21 PM
Big Smoky's Avatar
I LOVE the Vulcan kit! I ran a pusher in the past, but I like this way better. I think you'll be happy with it. I get 14psi @idle and 8@WOT with all my mods.
Old Nov 27, 2006 | 11:56 PM
Ph4tty's Avatar
Well if nothing else the vulcan kit makes pump swaps a walk in the park. The geno's kit is slightly different than mine, but with my current pump the 15psi guage is pegged at idle and sometimes at cruise. I can pull it down just past 12 wfo.
If you just ran some biodiesel you might want to check your fuel filter.
Old Nov 28, 2006 | 12:27 AM
Marine's Avatar
Veteran: Marine Corp
I love my Vulcan relo kit. I have another stocker just in case, and it is an easy pump swap. I have 14 psi and 11-12 with all my mods at wot.
Old Nov 28, 2006 | 02:07 AM
RAFTEN's Avatar
I am into my second year of running B100, can't remember when I last pumped dino diesel, so I always carry extra filters. This wasn't caused by a filter, as full power would return now and then. More like a combo of a used filter and failing LP.
Old Nov 28, 2006 | 07:08 AM
Joes truck's Avatar
vulcan draw straw
Hi im knew to the site ive seen a lot of post about the vulcan pusher pump kits. How about with the vulcan draw straw with that kit are yall seeing much of a diference with that add to it.
twhman
Feb 26, 2007 01:40 AM
sdsaw
Feb 10, 2007 09:36 PM
GlennRMK
Sep 5, 2006 11:24 PM
berettaman
Jul 19, 2006 10:02 AM
DuaneWKKC
Mar 17, 2006 08:00 AM
