probly a dumb question
i had a diablo puck and switched to the ez edge, the puck was only hooked the the vp44 trhe edge is not hooked to the vp44 can you run both at the same time? will it mess something up? give me more? or will they cancel each other out?
I dont know anything about Diablo Power Puck but, i know ez is a fuel and timing. You really dont want to stack a timing and timing chip, program, modual on top of eachother.
Hope it helps
ROb
Hope it helps
ROb
Agreeeeee, as it will add too much timing. I tried it only once.....superchip+ quad xzt+ and the truck shut down. More of something does not always improve things.
do somemore diggin i know that lots of folks stack smarty's. I thought that a power puck was just fuel. Someone is selling a power puck and something else in the dtr classifides that they had stacked on an 01
just my $.02
just my $.02
Maybe he should have asked if it was a good idea to run both, not just whether or not you CAN
I also would discourage running two timing advance mods. At light/no loads, this isn't a problem (and will have great mpg). But once the boost comes up, you will see more smoke, less power, and generally just poor performance in the real world. You might see more power on the dyno, but you might not. It depends a lot on your particular combo and the conditions and such.
Think of the vacuum advance function on a gasser distributor and you get the idea.
JH
JH
Thanks
calvin
Jan 4, 2003 10:41 AM
bigbaddiesel
Dec 7, 2002 07:40 PM
