Problems with FASS 2 already??
Old Aug 25, 2005 | 03:42 PM
ramtd02's Avatar
Changed my fuel filter yesterday and gained .5 psi of pressure across the range.
But today, I hit the old go button and she dropped to 6 psi and then built back upto 11. Either way i have never experianced anything less than 16 psi WOT.
Am I already having problems?? Hope not, this is supposed to be the reliable fix for the unreliable lift pump.
Old Aug 25, 2005 | 06:15 PM
rebal's Avatar
could just be some air that pushed its self out ,is it still doing it?
Old Aug 25, 2005 | 06:22 PM
Geico266's Avatar
Air in the system. It may take a few days to purge all of the air out. Give us a report in a week.
Old Aug 25, 2005 | 08:26 PM
mooseman's Avatar
If it don't go back up after a few days its probably a weak spring in the pump.
I had the same troubles with mine. I tore the spring out (manufactures recommendation) and put a slightly heavier one in. Now its 22 psi at idle and 16-18 at wot. Before I changed the spring Id draw it down to 2 psi at wot and idle at 18.
Mooseman
Old Aug 25, 2005 | 09:53 PM
RTillery's Avatar
I had something similar. After checking out everything, it turned out I was low on antifreeze in the FP isolater. Filled it back up and up to 17 psi again.
Old Aug 25, 2005 | 10:34 PM
AAmeeting's Avatar
The screen on the end of the pickup tube could also be clogged in the tank.
Old Aug 26, 2005 | 12:10 AM
ramtd02's Avatar
well its back up to 15 psi at WOT....another thing i thought of was the return line to the tank....doesnt the vp44 "throttle" the fuel return based on its fuel needs?? The more it needs the less it will send too the tank?
Old Aug 26, 2005 | 08:00 AM
Geico266's Avatar
Correct.
Must have had air in the FP guage line. Low FP readings are a common symptom after a fuel filter change.
No problems with the FASS II that I have read about. The spring replacement is the only issue I have read about and it is very rare.
Old Aug 26, 2005 | 09:14 AM
ramtd02's Avatar
well it wont be air in the fp guage line, as i have an electric guage.....
Old Aug 26, 2005 | 09:15 AM
ramtd02's Avatar
could this be my problem?? The VP44 getting ready too bite the bullet, so things ares slowly going wrong...instead of dead pedal?
Old Aug 26, 2005 | 09:24 AM
Geico266's Avatar
Electric FP guage readings are unreliable. Maybe you should add this to your signature.
Old Aug 26, 2005 | 10:37 AM
ramtd02's Avatar
Well it is reliable so far, as i have tested this with my test guage.....i never rely on a single guage too tell me whether or not something is working.....i always use a back up, whether the guage is mechanical or electrical, nothing is 100% accurate.
DJ Turbo.
Oct 13, 2011 09:11 PM
Buckshotmckee
16
Feb 14, 2006 12:32 PM
SilverDiesel
0
Nov 8, 2005 02:57 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
