Problem with BHAF Filter
Old Oct 25, 2007 | 06:31 PM
marine4life's Avatar
I just installed my BHAF from Napa yesterday and was very impressed with the kick in spoolup I received however after the install I noticed that there was a pretty loud knock coming from the engine compartment. you could only notice it when you were idling. The truck still had tons of power and I checked the fuel pressure yesterday and it is holding at around 12 psi at idle and 7-8 at WOT. I pulled the BHAF off today and ran it at idle with no intake, the knock was gone. I installed the stock intake back on, and again, no knock. I am confused as to how the BHAF could cause that, I thought maybe it was banging against the hood but ruled that out after checking. Any suggestions would help because I loved the way the turbo sang with it on. Thanks guys(and gals).
Bryan
Old Oct 25, 2007 | 08:16 PM
glenn-k's Avatar
Mine seems to suck forward a little when running then thump when I let off of the throttle abruptly. I fastened it down with large snap-ties.
Old Oct 26, 2007 | 02:22 PM
xtoyz17's Avatar
Could the metal screen around the filter be tapping on one of the screws on the shock tower that hold the air box?
Old Oct 26, 2007 | 04:26 PM
MATTIEBOB's Avatar
I Would Try To Secure It Somehow Ties, Baling Wire, Etc. The Try It Out.
Old Oct 26, 2007 | 05:35 PM
Thanks for the suggestions guys. It is pouring outside right now so I will try it out tomorrow. I will keep you guys updated.
Bryan
Old Oct 26, 2007 | 06:24 PM
RAF's Avatar
RAF
Mine does the same thing. For the most part I can only hear it when I have the hood up.
Old Oct 28, 2007 | 11:00 AM
ScreaminEagle's Avatar
What is a BHAF filter? Air? Does it help? I've been heasitant to change the stock air box. Is the turbo louder?
Old Oct 28, 2007 | 11:02 AM
xtoyz17's Avatar
Big Honkin Air Filter. It's an incredibly large air filter from napa and other various stores. It offers about the best flow you can get through the stock intake and more than the average owner will ever need.
Louder turbo, cooler egt's if the stock filter was a restriction, etc... etc...
Old Oct 28, 2007 | 11:05 AM
Anyone have a part number? Is there any differenct between this filter and the aftermarket expensive filter systems?
Old Oct 28, 2007 | 11:15 AM
xtoyz17's Avatar
Napa 2790
The aftermarket systems use different filters and usually replace the factory accordion pipe that goes from filter to turbo.
Old Oct 28, 2007 | 12:07 PM
Mopar1973man's Avatar
You should mount your filter minder in the back side of the filter and then you'll know if its sucking down first off...
Old Oct 28, 2007 | 12:24 PM
Does it matter if you have the sock over the filter?
Old Oct 28, 2007 | 12:36 PM
Dr. Evil's Avatar
Not really - the prefilter just makes the BHAF last longer.
Old Oct 28, 2007 | 12:49 PM
Ok, thanks. Just ordered the filter. Big price difference depending on where you get it. Napa web site said $73. The Wix through a local parts store is $69. I ordered it through the local Truck Centers from a Donaldson part# and it's $45.
Old Oct 28, 2007 | 01:30 PM
Dr. Evil's Avatar
Try here: www.fleetfilter.com:
http://www.fleetfilter.com/SearchResults2.asp
BTW, the prefilter also helps keep water off the paper BHAF.
