Problem With Adrenaline
Old Jun 24, 2008 | 11:24 PM
beefmandodge's Avatar
I installed adrenaline into my truck, if you run anything over level four it sputters, breaks down and cuts out while accleerating. It is losing fuel? Does anyone have any suggestions?
Old Jun 25, 2008 | 12:08 AM
qzilla's Avatar
The 2 things I would check are:
1) Make sure you have tight connection on the pump as a loose connections can make it do some sputtering.
2) Make sure you have plenty of fuel supply to the VP44, if not it can also act this way.
The other thing I would ask is does it do this under full throttle or when does it happen or just anytime you are on PL05 and over?
Old Jun 25, 2008 | 05:54 AM
it hapends on pL4 and up only at full throttle when u first take off
Old Jun 25, 2008 | 06:46 AM
J Lent's Avatar
Fuel pressure issue, better get a fuel pressure gauge working or vp44 will be toast fast.
scow1
Jan 18, 2011 10:22 AM
Tingram
Jan 15, 2009 09:38 PM
adidasman23
Aug 1, 2008 06:33 PM
Ramtuff06
31
Jun 25, 2008 12:07 PM
