pressurizing coolant system
Old May 23, 2009 | 12:47 AM
estrada5.9's Avatar
Ok so when i get on it hard pulling a decent load uphill with boost at 35-40 and pyro at 1000-1100 i am puking coolant due to blown head gasket. I was towing with 18 degrees of timing and I thats just to much i figure. So its set at 15 now.
Now for the question:
My o-rings are ten thousands I have heard that this is great for contact pressure but it is in such a small area that it can be bad.
Should in get shorter rings and if so what size.
I had 40,000 on the last head gasket so I figure the higher timing and the towing must have done it. anything would be helpful right now I don't wanna do the head gasket with those rings if they are not optimal for my application and I really am over the beating the tar out of my pickup just goin for reliable
Hows it go again FAST CHEAP RELIABLE pick any two right
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
plow
Jun 1, 2005 01:39 PM
popeyesides
Dec 6, 2004 03:43 PM
