Powermax TST question
Old Feb 8, 2008 | 11:13 PM
Jaxn51's Avatar
Anyone know if they do boost fooling? I want to stack one with my van Aaken. Then the other question would be, how do you connect the MAP sensor to both units?
Old Feb 9, 2008 | 01:44 AM
mopar-or-no-car's Avatar
Dosen't the van aaken do boost fooling? When I stacked my tst with my ez I asked tst and they said it would make more power with the tst connected to the engine side first then plug the other end of the tst into the van aaken and the other end of the van aaken into the other end of the map sensor plug that goes to the cab or whatever.
Old Feb 9, 2008 | 07:27 AM
Ph4tty's Avatar
Yes the TST boost fools the ecm.
Old Feb 9, 2008 | 09:32 AM
Jaxn51's Avatar
Ok then, they both do boost fooling. I wasn't sure about the TST. I will have to move my boost gauge hook-up to the TST harness input connection. If the van Aaken only sees a safe boost, it doesn't affect it's operation? I mean will it achieve full potential anyway? Sort of in the dark about this. TIA
Old Feb 9, 2008 | 07:01 PM
Jaxn51's Avatar
bumpity bump
Old Feb 9, 2008 | 08:35 PM
HOHN's Avatar
The VA will be unaffected by the boost fooling of the TST.
Connect it this way: MAP sensor--> TST--> VA-- Factory harness that connects to MAP sensor.
The TST needs to see the map sensor output directly.
Not all VA units do boost fooling. The earliest models only advanced timing and gave a hair more fuel-- no boost fooling.
All the VA units on the market now have boost fooling. So this is only an issue if you have a VERY old VA (ca. 1999-2000 or so).
jh
Old Feb 9, 2008 | 11:53 PM
Jaxn51's Avatar
Thanks to all who replied. Justin, my VA is a newer model, two years old. Btw, how is it that you know this? You must read a lot. ;-)
I found a 60hp Powermax, which is all I was really looking for and bought it from a forum member. It should go well with the 275s I found as well. Now, all I need is a free weekend to get everything installed.
Too many projects and not enough time.
Old Feb 10, 2008 | 09:43 AM
HOHN's Avatar
The scary thing is that even though I'm coming up on 5K posts, I've read at least 10X that, if you count here and my old TDR acct
Moobesor
19
Feb 28, 2008 01:27 AM
thek0rn
Apr 20, 2007 02:31 AM
dodgediesel
54
Mar 17, 2007 08:40 AM
dodgediesel
17
Nov 18, 2006 12:47 AM
CMN_NOT_STROKN
14
Oct 26, 2002 07:34 PM
