power modules
Old Jul 15, 2007 | 07:23 PM
kaffine krazed's Avatar
power modules
What are my options for power modules that do not tap the VP-44 wire? Thanks.
Old Jul 15, 2007 | 08:02 PM
pmtg's Avatar
to get you started...
Edge EZ
Smarty
Quadzilla XZT+ (edited)
VanAaken
Diablosport Power Puck
Superchips
Hypertech
Old Jul 16, 2007 | 12:58 AM
Ph4tty's Avatar
All the above options gives a timing bump and the max fuel the vp44 is supposed to put out- so hp levels should be the same across the board.
I like the smarty- makes the turbo want to spool and the cummins want to rev
Old Jul 16, 2007 | 10:53 AM
qzilla's Avatar
There should be a correction in that list.
Quadzilla XZT +
The regular XZT does tap the wire.
Also it is true that at peak levels most of the boxes will be similar, not the same but, similar. The difference is in the powerband and spool up.
Our new XZT+ spools much faster than any of the "boxes" listed, I guarantee that. Some say it is similar to a Smarty, I have not tested that myself.
bradley m
Jan 27, 2006 08:20 PM
steven25
Jan 27, 2006 08:45 AM
R Taylor
Nov 10, 2005 08:56 PM
gonzy
Nov 5, 2004 10:05 AM
turbo59pwr
Dec 9, 2003 12:03 AM
