Power issues
Old Feb 10, 2007 | 11:03 AM
natlchamp2k4's Avatar
If you have felt a shortage of power and are seeing low boost, check the pump tap wire. If came loose you will only be seeing 65hp and that will result in low boost.
Jamie
Old Feb 10, 2007 | 12:09 PM
John_P's Avatar
qzilla:
Good post on the COMP! Thanks for your help! Between all the DTR Members here, hopefully we can get "rfda_454" taken care of! That is what I love about this website!
Thanks to everyone else that came in to help this member too!
John_P
Old Feb 11, 2007 | 08:41 PM
rfda_454's Avatar
hey guys i just got back from deadwood and the shop was still full
I hopefully will get in there tomarrow or ill just do it out side. eather way i will hopefully i will fugure it out.
Thanks everyone
QZILLA what your saying makes sence. thanks for the help.
Usualy i have no trouble getting my truck into the shop when i need to but we have been real crazy lately all your guys help is awsome i just need to get after it
Thanks again.
Old Feb 11, 2007 | 10:32 PM
MNorby's Avatar
Hey Raddest Dude Alive 454.... shoulda used RFDA5.9 here Anyways glad you finally posted this up on here good luck
Old Feb 18, 2007 | 01:38 AM
rfda_454's Avatar
I finally got my truck into the shop tonight...
I checkede the injection pump tap wire and its fine i put my code reader back in it and it hasnt thrown a code since i cleared the overboost code last week.
so i cant figure that out. the motor seems to run ok since i cleared the code but it still doesnt put out the power that it did a few months back, and im still getting bad fuel milege. could it be the edge comp going bad. does that happen???? i checked the conections to the map sencor they were clean and dry. i pulled the map sencor out and it looks fine too.
so if it doesnt have any trouble codes now and my wires are all connected what could it be. it isnt blowing much black smoke like it used to,
all i know is it sucks, my buddy in his stock powersmoke can almost keep up with my and thats just not right!!!
Old Feb 19, 2007 | 03:02 PM
rfda_454's Avatar
is it possible that my edge comp is going bad, maby it isnt sending a signal to the pump? is that possible???
Old May 3, 2007 | 04:59 PM
silverbullet830's Avatar
i noticed a very tiny puff of black smoke when i started my truck a while ago. could a dirty MAP or IAT cause this? my main problem is if i take off easy and then stomp it before it shifts to 2nd, once it gets to about 2k it starts almost bucking. kind of like the fuel is being cut off and on, or like i was pumping the throttle and holding it in first gear. its weird. its not violent or anything but somthing isn't right. also every now and then there will be a very light bit of smoke from the exhaust. so i figure it might be a bad or dirty sensor (hopefully).
Old May 3, 2007 | 11:10 PM
Ph4tty's Avatar
I'm not sure why you brought this old thread back up Mr silverbullet, but the first thing you should do is read your codes with the key trick: without starting the truck turn the key on/off/on/off/on and the codes will be displayed the odometer.
I wouldn't be worried about a puff at startup though. Its normal as far as I can tell.
Old May 9, 2007 | 02:34 PM
yeah didn't check the date. think i found it on a search or somthin. sorry. i'm more worried about the bucking thing its doing guess i'll try pulling codes though i don't have a CEL so i don't think any have been set. thanks for the heads up though.
TxDiesel007
Aug 10, 2005 06:03 AM
greenworks
Oct 7, 2004 08:57 AM
kstrongsyj
Apr 26, 2004 10:02 PM
JBirney
Sep 25, 2003 09:48 PM
moneyman
Aug 21, 2003 05:14 PM
