power edge ez- level 5 & 6
Old Sep 11, 2003 | 11:47 AM
GONZO86's Avatar
my booklet only has up to level 4, but i was told that you can go to 5 & 6
does anyone which pins to put the jumper on to get those levels?
pins look like - ::. :::
thanks Gonzo86
Old Sep 11, 2003 | 12:09 PM
moneyman's Avatar
Re:power edge ez- level 5 & 6
I thing the first set of pins on the far left gives you 80 or 85. Call edge products and ask for justin. He can tell you
Old Sep 11, 2003 | 12:14 PM
AlpineRAM's Avatar
There are no more power levels AFAIK, but the second set of jumpers determines responsiveness. (AKA low boost fueling) to be able to detune the low boost fuel for very big injectors.
Just my 2c
AlpineRAM
Old Sep 11, 2003 | 04:44 PM
WTTD's Avatar
Here are the other jumper settings ::: ++: is 80HP
+:: +:: is 75HP
I have not had one do it, but the 75 and 80 settings have caused some seal failures in the rail. I don't set them up that high for customers.
www.westtexasturbodiesel.com
Old Sep 11, 2003 | 04:45 PM
phox_mulder's Avatar
Must remember, this is a 2003 EZ he is referring to.
Different animal than used for our old fashioned 2nd Gen 24Valvers.
phox
Old Sep 11, 2003 | 05:15 PM
WTTD's Avatar
Those are the settings for the 03, the 98-02 adjustments only control low boost fueling. On the 03's the pin position determines rail pressure.
Old Sep 12, 2003 | 08:43 AM
GONZO86's Avatar
I was told the 75hp was ::: +::, didnt look right with just one jumper.
i was putting on the boost elbow, had my thumb on the barbed hose outlet and it broke off, called edge and they told me $10, anybody have the same prob?
thanks for the info
GONZO86
Old Sep 12, 2003 | 09:59 AM
Mopar_Mudder's Avatar
I had to grind the end of my elbow off. The barbed end was too long and would hit the turbo houing when trying to screw it in.
Old Sep 12, 2003 | 10:32 AM
WTTD's Avatar
On all the earlier 03 EZ's the elbow was long, it is odd because some trucks required you to cut one barb off and others didn't. Now all the new EZ's have it cut off already.
Old Sep 12, 2003 | 07:24 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=WTTD link=board=7;threadid=19570;start=0#msg183684 date=1063316655]
[/quote]
This is the first I've heard of this, Chace. Did the info come from Edge? We've got about 75 of these critters on the street, pretty much all in the 80 pony setting, and nary a problem.
Rod
Old Sep 20, 2003 | 05:51 PM
GONZO86's Avatar
Is it safe to run the boost elbow without the edge ez hooked up, how about going to the dealer should this be removed or is it ok to leave in?
thanks again
gonzo
Old Sep 22, 2003 | 07:13 PM
Jeff K's Avatar
What are the different jumper settings for the '03 EZ. I have searched, but come up with nothing. Please tell me if what I have below is correct or not... ???
::: ++: is 80HP level 6
::: +:: is 75HP level 5
::: :++ is 70HP level 4
::: :+: is 60HP level 3 (default)
::: ::+ is 50HP level 2
::: ::: is 40HP level 1
jmccart
Jun 14, 2008 10:29 AM
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
