Power BRaking
Old Apr 15, 2003 | 06:31 PM
DieselFreak's Avatar
Power BRaking
With the mods I currenty have, I can not power brake my truck unless the ground is wet. Is there a sensor or something else that would prevent this? The truck pulls forward like it wants to, but it just doesn't. The more fuel you give it the engine bogs down when the brake petal is to the floor. Any info would help. THanks
Old Apr 15, 2003 | 06:34 PM
Cold Diesel's Avatar
Re:Power BRaking
Auto or stick?
Old Apr 15, 2003 | 06:42 PM
Re:Power BRaking
cold diesel,<br>It's an auto
Old Apr 15, 2003 | 06:59 PM
OlBlue's Avatar
Re:Power BRaking
Stock tranny?<br><br>Get boost higher maybe. Even if you have to let the truck roll a little with light braking to get boost and engine rpm up. Once rear tires start spinning, friction is greatly reduced and the pickup will likely stop moving forward. All told might be around 4' or 5' of travel. Once spinning you will also be able to back off on the brake pressure!
Old Apr 15, 2003 | 07:03 PM
quantrill88's Avatar
Re:Power BRaking
mine is a bone stock auto and i can brakestand a huge cloud of smoke. maybe its just a matter of manipulating the brakes right as the turbo spools up
Old Apr 15, 2003 | 07:22 PM
scottrod's Avatar
Re:Power BRaking
If yours is a later 01 model, you have rear disc brakes and they will hold way better than the drum brake rears.
So it might be harder to powerbrake.
Old Apr 15, 2003 | 10:56 PM
misterKTM's Avatar
Re:Power BRaking
Put a line lock in if you really want to do a show, and do less damage to brakes, convertor, and trans,
Old Apr 15, 2003 | 11:07 PM
BigBlue's Avatar
Re:Power BRaking
Mine can't powerbrake. Even with the comp on. My dad's bone stock 6.5L turbo diesel Chevy with 33's and 4.10's and auto can do it no prob. Maybe the 3.54 gears are the problem. To high a gear.
Old Apr 16, 2003 | 06:40 AM
Dodgezilla's Avatar
Re:Power BRaking
Mine will do it but not until the boost gets up there. Of course, I've only done it twice on dry pavement because it's killing the trans but it sure looks cool when 4 wheels are spinning.. ;D
Old Apr 16, 2003 | 06:41 AM
dodgeram's Avatar
Re:Power BRaking
a line loc is definatly the way to go ......much easier on stuff
Old Apr 16, 2003 | 06:54 AM
ET_178z's Avatar
Re:Power BRaking
You shouldnt have a problem with power braking, You have to first give enough brake to get the boost up and make the tires want to brake loose. Then ease off the brakes.... I can do it with my 2002 5-speed. All it has is a EZ.... I actually just did one the other day with a Powerstroke 6 speed and a trailer on... Check out the picture
Old Apr 16, 2003 | 07:09 AM
dodgeram's Avatar
Re:Power BRaking
how do you do it with a 5 speed .......please explain the tecnique ...as I am lost on this
Old Apr 16, 2003 | 07:14 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Power BRaking
[quote author=dodgeram link=board=7;threadid=13641;start=0#128573 date=1050494951]
[/quote]
First you put your front bumper against a large immovable object.....like somebody's 6.0 Powerstroke Ford........
Old Apr 16, 2003 | 07:21 AM
hellotbone's Avatar
Re:Power BRaking
I can't do it either unless its wet out or cold in the hot summer with my sticky tires there is no breaking loose.
Old Apr 16, 2003 | 07:23 AM
wheezer's Avatar
Re:Power BRaking
My 2001.5 w/auto, 4x4, and 3.55's did it here at 5000' altitude no problem, bone stock. I don't have posi though. When it gets boost, I think it would fry them just as easy if I had posi. I put an EZ on and it'll light 'em (it) up with a little puff of diesel smoke to go with it. 8)
